Activity Forums Apple Final Cut Pro Video Breakup
  • Video Breakup
    Posted by David Van hooser on January 6, 2017 at 11:20 pm
    I’m having an issue with FCP X 10.3. Can’t find a solution in any forums.
    I’m working on an 84 minute feature film. All looks good on the timeline, and when playing back from the timeline.
    But when I Share/Export to create my movie file, I get random ‘glitches’ upon playback where the video breaks up or pixellates for two or three frames. And this is almost always on a cut transition between two clips. The outgoing clip and/or the incoming clip break up into a brief pixellated image, then all is normal. To experiment, I’ve exported as Pro Res or H264; regardless, the same thing keeps happening, and not always in the same spots with the same clips.
    I have gone back to reimport the original clips, using them to replace existing clips. Sometimes that works, sometimes not, and often times these ‘glitches’ occur at entirely different spots the next time I Share/Export to create another movie file.
    I’m running out of options. Can’t find a solution. PLEASE HELP. Thanks.
    David
    Anton Antokhin replied 9 years, 8 months ago 3 Members · 3 Replies
  • Noah Kadner
    January 6, 2017 at 11:53 pm
    That can happen if the source footage has issues. Only way to fix is reimport any clips you find w glitches. Sometimes a reinstall of OSX/FCPX can fix this if the glitches are totally random.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • David Van hooser
    January 7, 2017 at 12:07 am
    Thanks, Noah.
    I will try those solutions and see what happens.
    I am always reluctant to do a reinstall or upgrade in the midst of a project, but will try that if the first solution fails.
    Much thanks again.
  • Anton Antokhin
    January 8, 2017 at 5:54 pm
    Have you tried using Compressor instead of the Share menu?
