Activity Forums Adobe After Effects Video Blending.
  • Video Blending.
    Posted by Billyshark on May 11, 2007 at 6:15 am
    Is there A way to blend together two video files? (Like where you can make the same person on the screen twice.) And have the persons opacity still look a 100%? Such as when I use effects channel then blend the two people are visible but are about at 50% opacity.
    Darby Edelen replied 19 years, 4 months ago 2 Members · 1 Reply
  • Darby Edelen
    May 12, 2007 at 4:59 am
    [BillyShark] “Like where you can make the same person on the screen twice.”
    The easiest/fastest way to do this is to use a stationary camera and shoot the same scene twice with the person performing one role the first time through and the other role the second time through. Provided you have control of the lighting and you don’t move the camera there shouldn’t be noticeable differences between the backgrounds of either shot and they can be combined with a simple mask. You see this technique a lot in TV shows that don’t have time for costly alternatives.
    If the characters cross over one another it becomes more complicated and some serious roto (masking) work or green screening will be required.
    You could look at this tutorial for some other ideas:
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=1&page=https://www.creativecow.net/articles/oconnell_pete/roto/index.html
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
