Activity › Forums › Adobe Premiere Pro › Video bitrate not matching target bitrate after compression
  • Video bitrate not matching target bitrate after compression
    Posted by Ronnie Howard on December 9, 2015 at 11:05 am
    Hello you lot,
    I’m trying to compress a video with a target bitrate of 15Mbps. However, the file that I end up with is only about 7Mbps.
    I just did a test to see what would happen if I set it to 50Mbps and it only came out at 9Mbps!
    I’m editing a HD project with raw MXFs in Premiere Pro that are 4K and have a bitrate of 252Mbps. I’ve scaled the 4K footage down to HD for a HD output.
    And my compression settings (which have been given to me by our client for TV output) are:
    h264 Mp4 AVC
    1280×720
    Main@ L4.1
    CBR
    Target bitrate: 15Mbps
    I have another sequence in the project with rushes from the same shoot which is exporting out at 10Mbps, which is closer than the 7Mbps.
    I’m sure there is a very logical reason as to why this is happening, but I can’t figure out why.
    Has anyone had a similar issue that they have resolved somehow?
    Any advice is very much appreciated.
    Ronnie Howard replied 10 years, 9 months ago 2 Members · 3 Replies
  • Vince Becquiot
    December 9, 2015 at 6:09 pm
    Hi Ronnie,
    Make sure you uncheck any “match source” check boxes in the export window.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Ronnie Howard
    December 9, 2015 at 10:50 pm
    Hi Vince
    Thanks for responding.
    I have unchecked the match source as I’m actually outputting at 1280×720.
    I even tried exporting out a prores and then compressing from that but it’s still coming out with a low bitrate.
    Very confusing.
  • Ronnie Howard
    December 10, 2015 at 10:39 am
    I figured it out.
    I had a screen capture video that took up a lot of the timeline that was 692Kbps, so I was trying to force data that wasn’t there.
    Doh!
