Activity › Forums › Adobe Encore DVD › Video audio out of sync once imported to Encore CS6
  • Video audio out of sync once imported to Encore CS6
    Posted by Scott Crowley on December 9, 2014 at 12:55 am
    Hello Everyone,
    I’ve been having some issues with Encore CS6 for mac lately. I copy VHS to DVD’s on the side and burn them through Encore.
    The software (Elgato Video Capture) records a .mp4 of the VHS. Usually I just import the video add some chapters it transcodes then burns.
    Recently though its started to un-sync the audio. The video will play fine outside of encore but as soon as it’s imported in the timeline, the playback and burn are all out of sync. I even used Adobe Media encoder to encode it to an MPEG-2 file before importing, same thing. I then tried to cut off a bit of the audio at the beginning to sync it. It worked for the first 5 minutes, but then again everything else became out of sync.
    Has anyone run into this problem before?
    Scott
    Scott Crowley replied 11 years, 9 months ago 2 Members · 2 Replies
  • Jeff Pulera
    December 9, 2014 at 2:51 pm
    Hi Scott,
    I’ve seen this reported when importing a single multiplexed file into Encore (audio and video as one file). Encore prefers separate assets.
    When you created the “MPEG-2 DVD” file in Media Encoder, you should’ve got TWO files, .m2v video and .wav audio. Is that the case?
    Jeff Pulera
    Safe Harbor Computers
  • Scott Crowley
    December 9, 2014 at 4:44 pm
    Hello Jeff,
    Thanks for the response.
    Yes it gave me both files which I imported as a timeline. The video looked way better but the audio was still out of sync.
    Scott
