Activity Forums Apple Final Cut Pro Legacy Video / Audio Disconnected on timeline
  • Video / Audio Disconnected on timeline
    Posted by Tom Mooney on June 5, 2006 at 8:12 pm
    I have 3, 1hr shows on DV that I loaded into FCP5 to do some editing on them. I digitized each show as a clip, when I put them on the timeline the audio plays out of sync with the video by the time it gets to the end of the show. It’s digitized to an array so it not a drive speed issue. What’s going on, rebooted nothing works. Thanks
    Kevin Monahan replied 20 years, 3 months ago 5 Members · 6 Replies
  • David Roth weiss
    June 5, 2006 at 8:41 pm
    Check the audio in the browser to make certain its 48khz — its possible it may show up as 47.xxx. Are you using a Panasonic deck??? If so, this happened to me… It turned a 6 hour job into a 15-hour job…
    DRW
  • Kerry Brown
    June 5, 2006 at 9:54 pm
    Go to: Sequence/Render Only/Mixdown
    Try this and then play the timeline.
    KB
  • Tom Mooney
    June 5, 2006 at 9:58 pm
    The machine is a Sony, it says it 48. I just tried to batch capture the first clip and it did the smae thing.
  • Tom Mooney
    June 5, 2006 at 10:45 pm
    It did not work, I guess I have to re-digitze in pieces, I can’t wait to find an answer.
  • Martin Sterling
    June 6, 2006 at 1:54 am
    My Experience with FCP is that you cannot capture a clip longer than 15-20 minutes long without running the chance of experiencing audio slippage. What I do is capture in overlapping 15 min blocks so once captured I can connect them back together referencing consecutive TC numbers. Hope that helps!
    G5 Dual 2.0 GHz processor, OSX.3.9
  • Kevin Monahan
    June 6, 2006 at 9:47 pm
    Not a fan of hour long captures either. Capture in 20 minute chunks for better performance.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
