Activity Forums Apple Final Cut Pro Video appears darker in FCPX
  • Video appears darker in FCPX
    Posted by Jay Soriano on April 1, 2020 at 2:42 pm
    This is a new. Why do my videos appear darker in FCPX? Doesn’t matter if it’s in the Viewer, Event Viewer or skimming in the browser. Is there some setting I’m missing causing this? It doesn’t matter what footage I import. Video brightness looks normal viewing seperately in Quicktime player and out to my video monitor via BMD Thunderbolt Shuttle.
    FCPX 10.4.6
    MacOS 10.13.6
    Macbook Pro 2011
    Jay Soriano replied 6 years, 5 months ago 2 Members · 3 Replies
  • Brad Hurley
    April 1, 2020 at 3:00 pm
    This sounds like a gamma issue to me. You should never trust Quicktime as it has well-documented gamma shifts; Quicktime always looks wrong when I use it (so I never use it). If what you see in FCPX is darker than what you see on your reference monitor, check the gamma settings that you used for calibration. My guess is that you’re using gamma 2.4 on your monitor but FCPX’s viewer on your uncalibrated screen is gamma 2.2. If you change your reference monitor’s gamma calibration to 2.2, they’ll likely be closer to matching in terms of brightness.
    Gamma 2.2 is the norm for computer monitors, which are mainly used in brightly lit offices. Gamma 2.4 is what you’d use for viewing on a television screen, which are mainly used in darker rooms. Cinema is gamma 2.6, I believe; it’s viewed in a controlled completely dark environment.
  • Brad Hurley
    April 1, 2020 at 3:02 pm
    Just to add: the thing to trust is your reference monitor, assuming you calibrated it, and that you calibrated it for whatever you’re delivering for (if for web, use Rec 709 gamma 2.2, if for widescreen TV use Rec 709 gamma 2.4).
  • Jay Soriano
    April 2, 2020 at 4:58 am
    Thanks for your reply Brad. Unfortunately gamma is not the issue. When I skim in the browser the image looks darker. Once I stop, the image looks normal.
