Video and Audio syncing issues after rendering in Movie Studio Platinum 13
I am struggling with this (and have since Platinum 11.0). I convert VHS tapes for people to DVD. I have always had the problem of the audio and video getting out of sync the longer the video plays. THIS ONLY OCCURS AFTER RENDERING. The original *.mpg that my capture software creates is PERFECTLY in sync, however I need to edit the video, clean it up and use DVD Architect to make the DVD. I have altered project settings, I have rendered to different formats, I have attempted to resync audio and video in third party programs such as VirtualDub. Nothing works.
What information do I need to give you? I’ll provide what I can below:
The original capture file specs are (from VLC):Stream 0
Type: Audio
Codec: MPEG Audio Layer 1/2/3 (mpga)
Channels: Stereo
Sample Rate: 48000 Hz
Bitrate: 224 kb/sStream 1
Type: Video
Codec: MPEG-1/2 Video (mpgv)
Resolution: 720×480
Frame Rate: 29.970029
Decoded Format: Planar 4:2:0 YUVI have tried matching these settings in Project Properties in Movie Studio. I have tried matching them in any type of rendered file that DVD Architect Supports. Nothing seems to work. When I render the file(s) the audio and video always desync. The two streams start out in sync but the longer the video plays, the further out of sync they get.
Please help! I’ve been struggling with this for years now and rendering 5 minute chunks of a 4 hour VHS video takes AGES! Not to mention, that’s not a solution to the problem, it’s just a work around as the audio and video still desync (but not noticeably).
