Activity Forums Adobe After Effects vibrating white color spectrum
  • vibrating white color spectrum
    Posted by Philipe Karlsson on January 30, 2011 at 9:57 pm
    Hello,
    Im trying to achieve a vibrating effect in the white colors in a project.
    I have been looking into different tutorials: flickering candles and street lights ec.t without any good results.
    I would like to have almost a vibrating white color spectrum.
    what would be a good and easy way to do accomplish this?
    tips and inputs are much appreciated,
    Philipe Karlsson replied 15 years, 7 months ago 3 Members · 4 Replies
  • Cory Petkovsek
    January 30, 2011 at 11:47 pm
    Without knowing what “good results” are to you or what a “vibrating effect” means to you, we can’t be any help getting you there. White is not a color spectrum.
    Taking a random guess at what you want, if I had an image with white in it and I wanted it to randomly cycle through colors I would use the “change color” effect. I’d set it to match white and filter it so it grabbed only my white object. Then I would reduce transform lightness to -50, transform saturation to 100 and put an expression on the transform hue with something like wiggle(1.2,180).
    Cory
    Cory Petkovsek
    Corporate Video
  • Tudor “ted” jelescu
    January 31, 2011 at 9:26 am
    If I understand correctly, you are trying to achieve a super bright light- if that is so, you need to work in 32 bit – adding a glow will help to give that illusion.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Philipe Karlsson
    January 31, 2011 at 5:57 pm
    Hi Cory,
    I should have been more specific about my project.
    But your guess is very correct. I never thought of the expression, I’ll give it a try.
    here is some reference material: https://vimeo.com/7107401 (the lights in the background).
    Thanks for you answer.
    Regards/
    Philipe
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Philipe Karlsson
    January 31, 2011 at 5:59 pm
    Hi Tudor,
    I’ll give it a try.
    Thanks for your answer.
    Regards/
    Philipe
