Activity Forums Maxon Cinema 4D Vibrate Tag
  • Vibrate Tag
    Posted by Adam Mercado on May 12, 2011 at 6:16 am
    I’m trying to get a group of 8 parametric cubes to wiggle independently. Much like you would do in After Effects by adding a wiggle() expression to each layers position and rotation properties, and each layer would behave differently. Wiggle adds/subtracts its value to the base value established by the layers initial properties, and modified by a unique random seed.
    However in C4D when I apply the Vibrate tag to my group of 8 cubes, they immediately jump to 0,0,0 position and cannot be moved from there, unless the Vibrate tag is removed or disabled.
    what would be the solution to achieve an AfterEffects wiggle-like behavior?
    Ronny Traufeller replied 15 years, 3 months ago 3 Members · 2 Replies
  • Randy Johnson
    May 12, 2011 at 10:56 am
    Place the cubes were you want them. Then place them in a NULL object that is at 0,0,0 and add the vibrate tag to the null.
    /Randy
  • Ronny Traufeller
    May 18, 2011 at 11:03 am
    an animated random effector mograph could save some money in this case, if you experienced in mograph you only have to raise the animation value in the random effector ….
    traufeller.de
