Activity › Forums › Apple Final Cut Pro Legacy › VHS/Hi8 Clips into FCP
  • VHS/Hi8 Clips into FCP
    Posted by Sean Hammes on November 20, 2012 at 7:06 pm
    I am wondering if it is possible to convert VHS and Hi8 videos to clips that I can directly import into Final Cut Pro?
    I don’t want the digital clips to be transferred directly to a DVD. The most important thing is that the digital clip can be easily used in FCP.
    Thank you very much.
    Scott Sheriff replied 13 years, 10 months ago 2 Members · 1 Reply
  • Scott Sheriff
    November 20, 2012 at 8:27 pm
    [Sean Hammes] “I am wondering if it is possible to convert VHS and Hi8 videos to clips that I can directly import into Final Cut Pro?”
    Yes it is. You either need a capture card type device, or a HDV/DVdeck with external inputs that can convert on the fly and pass thru on FW for FCP Log and Capture.
    Scott Sheriff
    SST Digital Media
    Multi-Camera Director, VFX and Post Production
    The Affordable Camera Dolly is your just right solution!
    “If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
