Activity › Forums › Blackmagic Design › VHS Capture via Intensity Pro – Black and White with No Sound…
  • Chad Pearson
    November 5, 2013 at 8:56 pm
    Are you using a Time Base Corrector (TBC) in between your VCR and your Blackmagic card? VHS tapes don’t produce a stable enough signal for digital capture without one, especially on “cheap” consumer VCR’s
  • Steve Mullins
    November 6, 2013 at 4:20 pm
    Im not no – shouldnt it be in colour at least?
    https://www.youtube.com/watch?v=tMA5aH_olAQ
    Whats the cheapest / best ish TBC outthere? Yes i’m using a el cheapo vhs deck (sony).
  • Steve Mullins
    November 22, 2013 at 12:31 pm
    I’m now using a JVC SVHS deck with TBC and its corrected the rolling – but its still in Black and white with no audio?
    https://postimg.org/image/otw2vvg4r/
  • Chad Pearson
    November 22, 2013 at 8:45 pm
    Have your configured the Blackmagic capture card in your computers control panel? There is an additional “Blackmagic Control Panel” installed with the Media Express software that has to be configured in addition to Media Express and Final Cut.
    Specifically, if you are seeing black and white, it is most likely the card is set to “Component” instead of Composite input mode. In Component video mode the same “Y” connector is used for the black and white portion of a YPbPr signal, whereas in Composite mode both the black and white and color portions come in on the same wire.
