Activity Forums Blackmagic Design VHS capture problems with fcp
  • VHS capture problems with fcp
    Posted by Greg Pilon on May 23, 2008 at 6:50 pm
    Well, I am trying to capture a vhs tape for a friend, and as I am capturing into fcp in the log and capture window I am seeing black flashes throughout the video. But when I plug the vhs into the tv, there are no flashes and no stuttering. Is this a sync problem with me using a non-controllable device? Any setting in the multibridge that need to be set? Thanks Greg
    J. Tad newberry replied 18 years ago 4 Members · 3 Replies
  • Jason Levy
    May 23, 2008 at 8:16 pm
    Sometime the signal coming off a vhs tape is fine to screen but just not stable enough to capture.
    You can try to first transfer it to Betacam SP (if you have access to one) and then play back through the beta deck’s TBC. That will stabilize it as much as possible and it may capture better.
    good luck.
    jason
  • Margus Voll
    May 24, 2008 at 6:40 am
    Hi.
    What i have done to “sync” vhs is i made pass trough tiny sony camera which has analogue in and firewire out.
    It gave me nice stable picture but only by fw not directly to capture card. It seems really hard for pro gear to negotiate with vhs with it’s unstable picture.
    Hope it helps.
    Margus
    https://iconstudios.eu
  • J. Tad newberry
    September 8, 2008 at 9:47 pm
    ya, i’m still looking for a good solution to capture all my old vhs tapes…
    thanks again!
    mh
