Activity Forums Apple Final Cut Pro Legacy VHS capture problem
  • VHS capture problem
    Posted by Anton Shu on December 12, 2007 at 2:21 pm
    Hello,
    I have a strange issue with my AJA IO and I really hope to get an advice from You.
    I have a S-VHS cassette recorder (sony SVO – 9620), I`m trying to capture a VHS material with final cut.
    The problem is, that during the capturing, I receive black and white signal, without color information. I use s-video cable. But when i plug the same cable not to AJA but in to my monitor, the video is normal, coloured.
    I`ve tryed composite mode also, but then I`m receiving no video signal at all
    Please help me
    Itamar Kool replied 18 years, 8 months ago 4 Members · 3 Replies
  • David Bogie
    December 12, 2007 at 6:07 pm
    Call AJA. Sounds like your box is dead or needs to be reset.
    Try the AJA forum.
    bogiesan
  • Rennie Klymyk
    December 12, 2007 at 7:21 pm
    Check your settings, make sure no other firewire wire devices are plugged into the same bus. You may need to download new drivers.
  • Itamar Kool
    December 12, 2007 at 8:45 pm
    I would say you need a player with a built in Time Base Corrector
    Kool En De Anderen
    MAC Pro 8 core/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
    http://www.koolendeanderen.nl
