  • Posted by Patrick Morrow on January 27, 2007 at 2:50 am
    All I want to do is mirror my power book display on a VGA output. I have tried everything and today it worked for a few minutes but then it was gone again. Also my video in FCP would stutter when the display changed in resolution. Is there a problem with my computer? I do not think so. Please help!
    Sincerely,
    Patrick Morrow
    13 replied 19 years, 8 months ago 2 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    January 27, 2007 at 3:50 am
    “I have tried everything”
    What exactly did you try?
  • Patrick Morrow
    January 27, 2007 at 4:09 am
    I tried all three VGA resolutions and all 3 other resolutions in all combinations. None of them worked and when it worked on a fluke it did not stay. I use the F7 key to bring it up on the screen, from there I would try to make it work.
    Thanks!!!
    Patrick Morrow
    13
    January 28, 2007 at 5:33 am
    When mirroring a display the computer looks at the setting of each display and must use the lower of the two screen resolutions. My guess is that your VGA display has a lower resolution then your Powerbooks built in LCD screen.
    If you are trying to use a VGA screen to preview your video don’t have it set to mirrored and tell FCP to play back on the second screen.
