Activity › Forums › Apple Final Cut Pro Legacy › VFR not working
VFR not working
Posted by Bob Auiler on September 16, 2009 at 9:51 pmHas anyone had problems with their VFR presets after upgrading to FCS3 and Kona 7?
FCS3
Mac Pro Dual Quad core Zenon
OSX 10.5.8
Kona 3 w/Driver version 7Bob Auiler | bob.auiler@mvpcollaborative.com
Jeremy Garchow replied 17 years ago 3 Members · 7 Replies -
Bob Auiler
September 17, 2009 at 4:19 pmHi Jeremy,
The AJA KONA 3 DVCProHD VFR presets have stopped removing duplicate frames. I’m not sure if it stopped working after the FCS update or the AJA update.
I installed this on a clone of the system drive to check it out so no damage has been done. If no one else is seeing the problem, it might be a good excuse to burn the weekend and do a clean install.
Jeremy Garchow
September 17, 2009 at 4:32 pmCould be. I had a buddy that happened to and a clean install fixed it.
But before that, I would uninstall and reinstall the Kona drivers. Use the AJA Uninstaller to uninstall frist, then reboot, then reinstall and reboot.
Jeremy
Bob Auiler
September 17, 2009 at 5:07 pmThanks for the reply Jeremy,
I did uninstall the KONA driver, but didn’t do the re-boot sequence that you suggest. I’ll give it a try.
Gary Adcock
September 18, 2009 at 3:51 pm[Jeremy Garchow] “But before that, I would uninstall and reinstall the Kona drivers. Use the AJA Uninstaller to uninstall frist, then reboot, then reinstall and reboot.
“Do not forget to also run the firmware updater that is in Applications > Aja Utilities folder > Kona Updater.
I am not seeing any issues with my test setup for FCS3 and Snow.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Bob Auiler
September 22, 2009 at 10:45 pmThanks for taking the time guys, the problem turned out to be hardware related. The input I was using was not seeing timecode. Switching to the other input got me back on the air.
My son goes to Columbia College in Chicago, so you can thank me for contributing a lot of money to your beautiful city.
Jeremy Garchow
September 22, 2009 at 10:49 pm[Bob Auiler] “so you can thank me for contributing a lot of money to your beautiful city. “
Thank you!
Jeremy
