Activity › Forums › Apple Final Cut Pro Legacy › VERY URGENT: Reconnecting offline media files?
  • VERY URGENT: Reconnecting offline media files?
    Posted by May Bolton on May 19, 2008 at 1:09 pm
    Hello all,
    Here is an old post I added last month but I’ve had no reply. If anyone can help, I’d be grateful, I’m really behind on this film and I can’t seem to resolve the problem (call it naivite!) Thanks:
    Hi everyone,
    I’m desperate for some help. I’ll start by explaining the background to my current problem and then the latest problem I’m having.
    A couple months ago I came to work on a FCP project that I hadn’t opened in a while (4-5 months). I would open it and it would load to about 3 or 4 % and then crash. I sought help on this problem and was advised that it might have been a single corrupt clip. Whatever it was, I followed the advice I was given and moved the related files that I had saved in the same place as the project file (all were saved on a small external HD), and moved it to a second external HD therefore breaking the link between the project file and the related media files. Since then I have been able to open the project file offline without any problem and have begun to reconnect the media files from my second external HD.
    I had assumed that if I reconnected the files one by one (while keeping a written log of each clip) then I could just move each media file that reconnected, back onto the original hard drive so that it is back in the same place as the original project file. I had also assumed that the project would now open with all the files reconnected and in place and that I could continue the process of reconnecting until I came across the corrupt clip, that I would then delete.
    Instead of the project file reopening with some of the reconnected files in place (the ones I moved back to the original HD), I am having to start the process all over again. Call me naive but I don’t understand why this is happening. I have only ever had time to do reconnecting in stages over the course of a few days but I keep finding that nothing is saved.
    The last time I tried to open the project file normally it crashed again. I’ve pasted my last crash log below for more information.
    Could someone offer any advice or clarification?
    J
    Final Cut Pro 4.5 HD
    Mac OS 10.4.11
    LAST CRASH LOG:
    Date/Time: 2008-04-07 15:30:28.589 +0100
    OS Version: 10.4.11 (Build 8S165)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Final Cut Pro HD 4.5.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [70]
    Version: 4.5 (4.5)
    Build Version: 2
    Project Name: FCPApp
    Source Version: 4860000
    PID: 270
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Thread 0 Crashed:
    0 …ple.CoreServices.CarbonCore 0x90bb5ab8 FSpMakeFSRef + 16
    1 …ple.CoreServices.CarbonCore 0x90bdf030 CallComponentFunctionCommon + 1044
    2 com.apple.LiveType.component 0x04d54cf4 LTQTCodecComponentDispatch + 3356
    3 …ple.CoreServices.CarbonCore 0x90bdf1cc CallComponentFunctionCommon + 1456
    4 com.apple.LiveType.component 0x04d55228 LTQTImportComponentDispatch + 88
    5 …ple.CoreServices.CarbonCore 0x90bdebb8 CallComponent + 260
    6 com.apple.QuickTime 0x94861fe0 MovieImportDataRef + 80
    7 com.apple.QuickTime 0x9497b464 newMovieFromFileFromComponent + 1044
    8 com.apple.QuickTime 0x949235b8 getNewMovieFromFileUsingImporters + 792
    9 com.apple.QuickTime 0x94922f64 NewMovieFromFilePriv + 756
    10 com.apple.QuickTime 0x949a95f4 NewMovieFromFile_priv + 20
    11 com.apple.QuickTime 0x949a95c8 NewMovieFromFile + 72
    12 …alCutPro.Plugins.QTM Reader 0x03f1ec14 NewMovieFromFileWithGWorld(MovieType***, short, short*, unsigned char*, short, unsigned char*, OpaqueGrafPtr*) + 116
    13 …alCutPro.Plugins.QTM Reader 0x03f2cfcc FileOpenDataCore(KGFileRec*) + 528
    14 …alCutPro.Plugins.QTM Reader 0x03f2d570 FileOpenData(KGDictInt*) + 88
    15 …alCutPro.Plugins.QTM Reader 0x03f449e8 PluginMainEntry(long, long, KGDictInt*, void*) + 2364
    16 com.apple.FinalCutPro 0x0024edc4 pKGOpenFile(KGFileRec*, unsigned long) + 212
    17 …alCutPro.Plugins.QTM Reader 0x03f2fbf0 FileGetInfo(KGDictInt*) + 232
    18 …alCutPro.Plugins.QTM Reader 0x03f44a18 PluginMainEntry(long, long, KGDictInt*, void*) + 2412
    19 com.apple.FinalCutPro 0x00250ae4 GetInfoFromReader(KGFileRec*, KGDictInt*, char*) + 452
    20 com.apple.FinalCutPro 0x00251e8c pKGFileAddOrCheckImport(KGFileSpec*, char*, KGDictInt*, KGFileRec**, KGFileRec**) + 776
    21 com.apple.FinalCutPro 0x00251960 pKGFileAdd(KGFileSpec*, char*, KGDictInt*, KGFileRec**) + 48
    22 …CutPro.Plugins.Relink Media 0x03fae91c MakeFileEntryOnline(KGLinkInfoRec*, KGFileSpec*, unsigned char*) + 340
    23 …CutPro.Plugins.Relink Media 0x03fb4d60 FindMissingFiles(KGDictInt*, unsigned char, unsigned char) + 4432
    24 …CutPro.Plugins.Relink Media 0x03fb54cc PluginMainEntry(long, long, KGDictInt*, void*) + 780
    25 com.apple.FinalCutPro 0x001df5b8 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 360
    26 com.apple.FinalCutPro 0x001df78c HandleCommand(long, unsigned char, unsigned char, unsigned char) + 256
    27 com.apple.FinalCutPro 0x001e2aac HandleMouseDown(EventRecord*) + 624
    28 com.apple.FinalCutPro 0x001e5d84 Process1MacEvent(KGDictInt*) + 2520
    29 com.apple.FinalCutPro 0x001e625c KGMainEvent + 104
    30 com.apple.FinalCutPro 0x003de4b4 main + 832
    31 com.apple.FinalCutPro 0x0000430c _start + 392
    32 com.apple.FinalCutPro 0x00004180 start + 48
    Thread 1:
    0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
    1 libSystem.B.dylib 0x9000b29c mach_msg + 60
    2 com.apple.CoreFoundation 0x907de9b8 __CFRunLoopRun + 832
    3 com.apple.CoreFoundation 0x907de2bc CFRunLoopRunSpecific + 268
    4 com.apple.CoreFoundation 0x907ed71c CFRunLoopRun + 52
    5 com.apple.DVCPROHDMuxer 0x06e1c2bc AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 396
    6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 2:
    4 com.apple.audio.CoreAudio 0x91459524 HALRunLoop::OwnThread(void*) + 264
    5 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
    Thread 3:
    0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
    1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
    2 …ple.CoreServices.CarbonCore 0x90bf93f4 TSWaitOnSemaphoreCommon + 176
    3 …ickTimeComponents.component 0x99e16174 ReadSchedulerThreadEntryPoint + 5316
    4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 4:
    0 libSystem.B.dylib 0x9002f08c kevent + 12
    1 com.apple.DesktopServices 0x92af8e50 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
    2 …ple.CoreServices.CarbonCore 0x90bc6794 PrivateMPEntryPoint + 76
    3 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 5:
    0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8
    1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480
    2 …ple.CoreServices.CarbonCore 0x90bc6984 MPWaitOnQueue + 224
    3 com.apple.DesktopServices 0x92af94cc TNodeSyncTask::SyncTaskProc(void*) + 116
    4 …ple.CoreServices.CarbonCore 0x90bc6794 PrivateMPEntryPoint + 76
    5 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 6:
    3 …ple.CoreServices.CarbonCore 0x90c03e9c AIOFileThread(void*) + 520
    Thread 0 crashed with PPC Thread State 64:
    srr0: 0x0000000090bb5ab8 srr1: 0x000000000200f030 vrsave: 0x0000000000000000
    cr: 0x24242222 xer: 0x0000000000000004 lr: 0x0000000004d54cf4 ctr: 0x0000000090bb5aa8
    r0: 0x0000000004d54cf4 r1: 0x00000000bfffd9d0 r2: 0x0000000000000006 r3: 0x0000000000000000
    r4: 0x00000000bfffdac0 r5: 0x0000000000000018 r6: 0x0000000074653f2e r7: 0x0000000069707200
    r8: 0x00000000746c6573 r9: 0x0000000000000000 r10: 0x00000000686f70ff r11: 0x0000000004d5d6dc
    r12: 0x0000000090bb5aa8 r13: 0x00000000fffff800 r14: 0x00000000bfffde20 r15: 0x00000000bfffde1c
    r16: 0x0000000000000000 r17: 0x00000000bfffe78c r18: 0x00000000bfffde2c r19: 0x00000000054bd884
    r20: 0x0000000000000000 r21: 0x0000000000000000 r22: 0x00000000616c6973 r23: 0x0000000000000000
    r24: 0x0000000000000000 r25: 0x00000000054bdd08 r26: 0x0000000000000000 r27: 0x0000000000000000
    r28: 0x000000000f49c980 r29: 0x00000000bfffddb4 r30: 0x0000000000000000 r31: 0x0000000090bdec24
    Binary Images Description:
    0x1000 – 0x434fff com.apple.FinalCutPro 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Final Cut Pro
    0x12b5000 – 0x12b9fff com.apple.FinalCutPro.Plugins.AudioGroupsExport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x12bd000 – 0x12c2fff com.apple.FinalCutPro.Plugins.Cache Manager 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x12d4000 – 0x12e3fff com.apple.FinalCutPro.Plugins.AudioMixer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x12e8000 – 0x12ebfff com.apple.FinalCutPro.Plugins.CTHelper 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0x12ee000 – 0x12f5fff com.apple.FinalCutPro.Plugins.Effect Builder 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0x12f8000 – 0x12fcfff com.apple.FinalCutPro.Plugins.LayerFileReader 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0x151d000 – 0x154afff com.apple.FinalCutPro.Plugins.AfterEffects 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x1557000 – 0x15e2fff com.apple.FinalCutPro.Plugins.Browser 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0x15fb000 – 0x1601fff com.apple.FinalCutPro.Plugins.MolokiniSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0x16a5000 – 0x16b7fff com.apple.FinalCutPro.CinemaTools 2.2 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0x16c0000 – 0x16d9fff com.apple.FinalCutPro.Plugins.EditTape 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0x16df000 – 0x1724fff com.apple.FinalCutPro.Plugins.EDL Export 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0x1735000 – 0x1742fff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0x1751000 – 0x177dfff com.apple.FinalCutPro.Plugins.FCS Engine 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0x178b000 – 0x179bfff com.apple.FinalCutPro.Plugins.FilterCustomEd 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0x179f000 – 0x17b2fff com.apple.FinalCutPro.Plugins.FilterViewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0x17b6000 – 0x17cdfff com.apple.FinalCutPro.Plugins.Flash 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0x17d8000 – 0x17e4fff com.apple.FinalCutPro.Plugins.GenViewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0x17e8000 – 0x17f7fff com.apple.FinalCutPro.Plugins.Movie Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x17fc000 – 0x17fdfff com.apple.FinalCutPro.Plugins.Text Window 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0x3c84000 – 0x3caefff com.apple.FinalCutPro.Plugins.G4 Accelerator 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/G4 Accelerator.bundle/Contents/MacOS/G4 Accelerator
    0x3cb5000 – 0x3ccbfff MolokiniTranslation /Final Cut Pro HD 4.5.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0x3ce6000 – 0x3ce9fff com.apple.FinalCutPro.Plugins.NuggetExport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0x3cec000 – 0x3cf3fff com.apple.FinalCutPro.Plugins.Perf Analyzer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0x3e05000 – 0x3e4afff com.apple.FinalCutPro.Plugins.Media Manager 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0x3e56000 – 0x3e6dfff com.apple.FinalCutPro.Plugins.Motion Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0x3e72000 – 0x3e84fff com.apple.FinalCutPro.Plugins.Movie Analyzer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0x3e90000 – 0x3ef7fff com.apple.FinalCutPro.Plugins.OMF Audio Export 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0x3f0f000 – 0x3f18fff com.apple.FinalCutPro.Plugins.Pulldown Support 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0x3f1d000 – 0x3f49fff com.apple.FinalCutPro.Plugins.QTM Reader 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0x3f56000 – 0x3f8bfff com.apple.FinalCutPro.Plugins.QTRtEffects 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QTRtEffects.bundle/Contents/MacOS/QTRtEffects
    0x3f9f000 – 0x3fa7fff com.apple.FinalCutPro.Plugins.QuickView 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0x3faa000 – 0x3fb5fff com.apple.FinalCutPro.Plugins.Relink Media 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0x3fba000 – 0x402bfff com.apple.FinalCutPro.Plugins.Timeline Editor 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0x403d000 – 0x4043fff com.apple.FinalCutPro.Plugins.Transcoder 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0x4048000 – 0x405afff com.apple.FinalCutPro.Plugins.Transition Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0x405f000 – 0x4076fff com.apple.FinalCutPro.Plugins.Trimming 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0x407b000 – 0x4082fff com.apple.FinalCutPro.Plugins.VDUSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0x4086000 – 0x4097fff com.apple.FinalCutPro.Plugins.VideoLog 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0x409c000 – 0x40b6fff com.apple.FinalCutPro.Plugins.VoiceOver 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0x40be000 – 0x40cffff com.apple.FinalCutPro.Plugins.Waveform Monitor 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Waveform Monitor.bundle/Contents/MacOS/Waveform Monitor
    0x40d4000 – 0x4170fff com.apple.FinalCutPro.Plugins.XML Support 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0x4474000 – 0x4484fff com.apple.FCP Uncompressed 422.component 1.0.5 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x44fc000 – 0x44fdfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
    0x4d53000 – 0x4d5cfff com.apple.LiveType.component 1.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x4d68000 – 0x4dccfff com.DivXInc.DivXDecoder 6.6.0 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x4dda000 – 0x4e53fff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
    0x503f000 – 0x50b6fff com.apple.DVCPROHDCodec 1.0 (112) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x50cc000 – 0x5145fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x51e6000 – 0x51fffff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
    0x5223000 – 0x522afff com.unsanity.smartcrashreports Smart Crash Reports version 1.2.1 (1.2.1) /Users/hannahdee/Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
    0x529c000 – 0x52a0fff com.apple.iokit.IOQTComponents 1.4 /System/Library/Components/IOQTComponents.component/Contents/MacOS/IOQTComponents
    0x538f000 – 0x53aefff com.apple.fcp.DVOutputUnit 1.2 /Final Cut Pro HD 4.5.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0x5493000 – 0x54aefff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x5605000 – 0x5714fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x5743000 – 0x599afff com.apple.ATIRadeon8500GLDriver 1.4.18 (4.1.8) /System/Library/Extensions/ATIRadeon8500GLDriver.bundle/Contents/MacOS/ATIRadeon8500GLDriver
    0x6c05000 – 0x6c8efff com.apple.DVCPROHDAudio 1.0 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x6e05000 – 0x6e97fff com.apple.DVCPROHDMuxer 1.0 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x6ec6000 – 0x6f23fff com.apple.DVCPROHDVideoOutput 1.0 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x6f36000 – 0x6f6ffff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x6f75000 – 0x6f7cfff com.apple.DesktopVideoOut 1.2.1 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x6f80000 – 0x6f8afff com.apple.IOFWDVComponents 1.7.9 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x7100000 – 0x71c2fff com.apple.audio.units.Components 1.3.4 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0xa572000 – 0xa5c13c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
    0xa5c13d0 – 0xa5d96bd Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia
    0xa6a4000 – 0xa8ddfff net.telestream.wmv.import 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0xa913000 – 0xaac7fff net.telestream.wmv.advanced 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0xd56e760 – 0xd56e812 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
    0xd56ea00 – 0xd56eab5 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue
    0xd56ecd0 – 0xd56ed73 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime
    0xd56ede0 – 0xd56ee57 CFMPriv_System PEF binary: CFMPriv_System
    0xd56f0d0 – 0xd56f1a0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
    0xd56f210 – 0xd56f2e3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
    0xd56f3b0 – 0xd56f46b CFMPriv_Help PEF binary: CFMPriv_Help
    0xd56f470 – 0xd56f53a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
    0xd56f5b0 – 0xd56f686 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
    0xd56f6f0 – 0xd56f7c3 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
    0xd56f840 – 0xd56f925 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
    0xd56f990 – 0xd56fa66 CFMPriv_OpenScriptingMacBLib PEF binary: CFMPriv_OpenScriptingMacBLib
    0xd56fb30 – 0xd56fbee CFMPriv_Print PEF binary: CFMPriv_Print
    0xd56fc00 – 0xd56fccd CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
    0xd56fd40 – 0xd56fe22 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
    0xd56fe90 – 0xd56ff63 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
    0xd56ffd0 – 0xd5700a3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
    0xd570170 – 0xd570232 CFMPriv_AE PEF binary: CFMPriv_AE
    0xd570240 – 0xd570305 CFMPriv_ATS PEF binary: CFMPriv_ATS
    0xd570370 – 0xd570447 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
    0xd5704c0 – 0xd5705a3 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
    0xd570610 – 0xd5706ea CFMPriv_HIServices PEF binary: CFMPriv_HIServices
    0xd570750 – 0xd570830 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
    0xd5708b0 – 0xd570996 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
    0xd570a60 – 0xd570b37 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
    0xd570b40 – 0xd570c02 CFMPriv_QD PEF binary: CFMPriv_QD
    0xd570cf0 – 0xd570dd9 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
    0xd605000 – 0xdaeb393 PEF binary:
    0xe9cf000 – 0xe9e5fff libJapaneseConverter.dylib /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0x10000000 – 0x10048fff com.apple.fcp.AudioMixEngine 1.5.6 /Final Cut Pro HD 4.5.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x41410000 – 0x414affff com.apple.QuickTimeImporters.component 7.2 /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
    0x419b0000 – 0x419effff com.apple.QuickTimeFireWireDV.component 7.2 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0x70090000 – 0x700e6fff com.apple.LiveType.framework 1.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0x70241000 – 0x70299fff com.apple.swamp.ServiceControl 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x72e36000 – 0x72f5bfff com.apple.stomp.transcoding 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x80ca7000 – 0x80cfefff com.apple.swamp.SwampService 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x81a84000 – 0x81adafff com.apple.swamp.RequestProcessing 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x835a6000 – 0x83612fff com.apple.swamp.SwampCore 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x83663000 – 0x836bafff com.apple.swamp.SwampExecutor 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x83b31000 – 0x83b42fff com.apple.stomp.MediaServerAPI 1.2.1 /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0x83b6f000 – 0x83b82fff com.apple.swamp.ClusterManager 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x83d97000 – 0x83deffff com.apple.swamp.SwampUtil 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x83ec0000 – 0x83f14fff com.apple.stomp.FilterUI 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x85041000 – 0x8504afff com.apple.stomp.StompUtil 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x85065000 – 0x850e3fff com.apple.stomp.StompTypes 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x86ed3000 – 0x86f91fff com.apple.AECore 1.2.1 /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x8831d000 – 0x883aefff com.apple.swamp.do 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x8a200000 – 0x8a229fff com.apple.swamp.SwampTypes 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x8a599000 – 0x8a5f5fff com.apple.swamp.Status 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x8a7fa000 – 0x8a85efff com.apple.swamp.ContentControl 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x8b545000 – 0x8b5a8fff com.apple.swamp.SwampUI 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x8b709000 – 0x8b7d1fff com.apple.swamp. JobControl 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x8ba31000 – 0x8ba39fff com.apple.Helium 1.0.1 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0x8c31e000 – 0x8c331fff com.apple.AERegistration 1.2 (41) /Final Cut Pro HD 4.5.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0x8c770000 – 0x8c7e3fff com.apple.stomp.StompUI 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x8cae4000 – 0x8cb10fff com.apple.stomp.ImageProcessing 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x8cb52000 – 0x8cb5afff com.apple.AEProfiling 1.2 (8) /Final Cut Pro HD 4.5.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0x8cba7000 – 0x8cba7fff com.apple.swamp.swamp 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0x8cbaa000 – 0x8cbaafff com.apple.stomp.stomp 1.2.1 /Library/Frameworks/Compressor.framework/Compressor
    0x8f4f0000 – 0x8f4f5fff com.apple.CoreMediaAuthoringPrivate 1.2 /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate
    0x8f840000 – 0x8f86efff com.apple.CoreMediaPrivate 1.4 /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
    0x8fe00000 – 0x8fe52fff dyld 46.16 /usr/lib/dyld
    0x90000000 – 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
    0x90214000 – 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
    0x9021b000 – 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90293000 – 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x90373000 – 0x9072efff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x907bb000 – 0x90895fff com.apple.CoreFoundation 6.4.9 (368.31) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x908de000 – 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x908e0000 – 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
    0x90a3c000 – 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
    0x90aea000 – 0x90b5cfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90b72000 – 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
    0x90b8b000 – 0x90e62fff com.apple.CoreServices.CarbonCore 681.17 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90ec8000 – 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x90f92000 – 0x90fd4fff com.apple.CFNetwork 4.0 (129.22) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x90fe9000 – 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
    0x91011000 – 0x91092fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x910d8000 – 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x91112000 – 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
    0x91123000 – 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x913dd000 – 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x913ed000 – 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
    0x913f9000 – 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x91434000 – 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
    0x91444000 – 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x914fc000 – 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x914fe000 – 0x91536fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x91551000 – 0x91623fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x91676000 – 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x9174e000 – 0x91805fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x91842000 – 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x918cf000 – 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x91904000 – 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
    0x9193c000 – 0x9197efff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x9199a000 – 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x919bc000 – 0x91a02fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x91a19000 – 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
    0x91b2e000 – 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
    0x91b48000 – 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91b6c000 – 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x91c72000 – 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x91c78000 – 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
    0x91ce7000 – 0x91d24fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91d2b000 – 0x91d45fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91d4a000 – 0x91d4dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91d4f000 – 0x91e2dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x91e4d000 – 0x91e4dfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91e4f000 – 0x91f34fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91f3c000 – 0x91f5bfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91fc7000 – 0x92035fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x92040000 – 0x920d5fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x920ef000 – 0x92677fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x926aa000 – 0x929d5fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x92a05000 – 0x92af3fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92af6000 – 0x92b7efff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x92bbf000 – 0x92deafff com.apple.Foundation 6.4.9 (567.36) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92f17000 – 0x92f35fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92f40000 – 0x92f9afff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92fb8000 – 0x92fb8fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92fba000 – 0x92fcefff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92fe6000 – 0x92ff6fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x93002000 – 0x93017fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x93029000 – 0x930b0fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x930c4000 – 0x930cffff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x930d9000 – 0x93106fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x93120000 – 0x9312ffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x9313b000 – 0x931a1fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x931d2000 – 0x93221fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x9324f000 – 0x9326cfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x9327e000 – 0x9328bfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x93294000 – 0x935a2fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x936f2000 – 0x936fefff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x93703000 – 0x93723fff com.apple.DirectoryService.Framework 3.3 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93797000 – 0x937b7fff libmx.A.dylib /usr/lib/libmx.A.dylib
    0x937bd000 – 0x937bdfff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x937bf000 – 0x93df2fff com.apple.AppKit 6.4.9 (824.44) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9417f000 – 0x941f1fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x9422a000 – 0x942effff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x94342000 – 0x94342fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x94344000 – 0x94504fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9454e000 – 0x9458bfff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x94593000 – 0x945e3fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x945ec000 – 0x94606fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x947b4000 – 0x947c3fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x947cb000 – 0x947d8fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9481e000 – 0x94837fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x9483e000 – 0x94b68fff com.apple.QuickTime 7.4.0 (92) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94c4e000 – 0x94cbffff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x94e34000 – 0x94f64fff com.apple.AddressBook.framework 4.0.6 (490) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x94ff7000 – 0x95006fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x9500e000 – 0x9503bfff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x95042000 – 0x95052fff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
    0x95056000 – 0x95085fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
    0x95095000 – 0x950b2fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
    0x97aea000 – 0x97b09fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x98220000 – 0x982e1fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x9830c000 – 0x9830dfff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
    0x9830f000 – 0x9831cfff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x99dfe000 – 0x9a9c4fff com.apple.QuickTimeComponents.component 7.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x9ac1d000 – 0x9ac21fff com.apple.QuickTimeH264.component 7.2 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x9ac23000 – 0x9ad32fff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x9aea9000 – 0x9af76fff com.apple.QuickTimeMPEG4.component 7.2 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9b944000 – 0x9b945fff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9b952000 – 0x9b996fff com.apple.viceroy.codec 31.0 (31) /System/Library/Components/VCH263Codec.component/VCH263Codec
    Model: PowerMac6,4, BootROM 4.9.2f1, 1 processors, PowerPC G4 (1.5), 1.25 GHz, 768 MB
    Graphics: ATI Radeon 9200, ATY,RV280, AGP, 32 MB
    Memory Module: DIMM0/J2, 256 MB, DDR SDRAM, PC2700U-25330
    Memory Module: DIMM1/J1, 512 MB, DDR SDRAM, PC2700U-25330
    Network Service: Internal Modem, PPP (PPPSerial), modem
    Network Service: Built-in Ethernet, Ethernet, en0
    Parallel ATA Device: PIONEER DVD-RW DVR-107D
    Parallel ATA Device: Maxtor 6Y080L0, 76.33 GB
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: Apple Optical USB Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    FireWire Device: LaCie FW800 Big Disk drive LUN 0, LaCie Group SA, Up to 400 Mb/sec
    FireWire Device: LaCie d2 Extreme LUN 0, LaCie Group SA, Up to 400 Mb/sec
    Rafael Amador replied 18 years, 4 months ago 5 Members · 12 Replies
  • 12 Replies
  • Rafael Amador
    May 19, 2008 at 1:57 pm
    Hi Jinan,
    What kind of elements you use in your project?
    Just footage? Graphics?
    Can you open other projects without problems?
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Gary Adcock
    May 19, 2008 at 2:23 pm
    [Jinan Coulter] “Model: PowerMac6,4, BootROM 4.9.2f1, 1 processors, PowerPC G4 (1.5), 1.25 GHz, 768 MB “
    Running OS 10.4.11 on single processor G4 with less than 1 gig of RAM would be your problem.
    You have updated your OS beyond the apps reach,
    looking at the crash log– the first lines are telling you that it cannot find the carbon drivers – its OS 9 stuff in carbon world – OSX drivers are written in Cocoa.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • May Bolton
    May 19, 2008 at 3:10 pm
    Other FCP projects on my computer open just fine. I just have normal footage, a few titles made in Livetype.
    x
  • May Bolton
    May 19, 2008 at 3:13 pm
    That sounds pretty serious. Although my other Final Cut projects open fine on this computer, it’s just this project that used to crash. Why would that be?
    Also, if it is the problem you mentioned, how would I fix it?
    Thanks x
  • Kevin Hamm
    May 19, 2008 at 9:24 pm
    Ok, first off, Carbon V Cocoa is a non-starter. Several of the Pro Apps use Carbon and Cocoa libraries, and Final Cut most certainly does.
    If you were able to open the project completely from the 2nd drive and it worked after you reconnected the media, it’s not Final Cut that is the problem. It’s most likely your 1st drive. In my experience, when a drive starts to fail, it’s subtle and causes weird bits, but programs like FCP that grab and hold onto so many large files tend to run into the errors faster and harder.
    If you’ve heard your drive click-and-spin-up-then-down and your finder has stalled a bit, it’s definitely the drive failure. If you’re just having issues with it when this large project is on the drive, you may just have a bad sector.
    Get DiskWarrior and test the drive, you’ll know then, but back your stuff up and off that drive just to save it.
    Kevin Hamm
    Video, Web, Print and coloring books.
  • Rafael Amador
    May 20, 2008 at 11:18 am
    Hi Jinan,
    It seems that the application crash when is trying to find a LiveType component.
    Try to put off-line the LiveType files that you have in your project.
    JVC DTV-17″
  • May Bolton
    May 22, 2008 at 12:55 pm
    Hey Rafael,
    Thank you, it was exactly that. I deleted all of the livetype files and the project opened completely without crashing while I had both hard drives on (so not offline).
    Can I ask you why you think that may have happened and what I could do differently to avoid a repeat?
    Also below is my latest crash log (the one just minutes before I deleted the livetype files. I am clueless as to how to read these, do you see anything else that I should be concerned about?
    A couple other posters in this thread mentioned that from looking at the crash log, I have updated my OS beyond the system’s capabilities: I’m running OS 10.4.11 on “single processor G4 with less than 1 gig of RAM” (as Kevin put it) and that’s another problem. ANy ideas on this?
    Thanks for all your help
  • May Bolton
    May 22, 2008 at 12:58 pm
    I meant to say in my last post that Gary was explaining about my OS compatibility, not Kevin. Sorry about the mix up!
  • May Bolton
    May 22, 2008 at 1:02 pm
    Hi Gary,
    Thanks for your help. I tried Rafael’s advice first and deleted all of the livetype files associated with the project and the project opened completely without crashing, so that was definitely one of the problems that contributed to the crashing. I’ve opened the project again since with everything online, and it’s still opening fine.
    I have, however, pasted my latest crash log below (the one just minutes before I deleted the livetype files). What can I do to fix the problem you mentioned of running OS 10.4.11 on “single processor G4 with less than 1 gig of RAM”?
    Date/Time: 2008-05-22 12:50:43.719 +0100
    Report Version: 4
    Version: 4.5 (4.5)
    Build Version: 2
    PID: 330
    Thread: 0
    Thread 0 Crashed:
    2 com.apple.LiveType.component 0x04d4bcf4 LTQTCodecComponentDispatch + 3356
    4 com.apple.LiveType.component 0x04d4c228 LTQTImportComponentDispatch + 88
    6 com.apple.QuickTime 0x94870fe0 MovieImportDataRef + 80
    7 com.apple.QuickTime 0x9498a464 newMovieFromFileFromComponent + 1044
    8 com.apple.QuickTime 0x949325b8 getNewMovieFromFileUsingImporters + 792
    9 com.apple.QuickTime 0x94931f64 NewMovieFromFilePriv + 756
    10 com.apple.QuickTime 0x949b85f4 NewMovieFromFile_priv + 20
    11 com.apple.QuickTime 0x949b85c8 NewMovieFromFile + 72
    12 …alCutPro.Plugins.QTM Reader 0x03f12c14 NewMovieFromFileWithGWorld(MovieType***, short, short*, unsigned char*, short, unsigned char*, OpaqueGrafPtr*) + 116
    13 …alCutPro.Plugins.QTM Reader 0x03f20fcc FileOpenDataCore(KGFileRec*) + 528
    14 …alCutPro.Plugins.QTM Reader 0x03f21570 FileOpenData(KGDictInt*) + 88
    15 …alCutPro.Plugins.QTM Reader 0x03f389e8 PluginMainEntry(long, long, KGDictInt*, void*) + 2364
    17 …alCutPro.Plugins.QTM Reader 0x03f25130 FileValidateInfo(KGDictInt*) + 392
    18 …alCutPro.Plugins.QTM Reader 0x03f38a28 PluginMainEntry(long, long, KGDictInt*, void*) + 2428
    22 com.apple.FinalCutPro 0x001bb568 GetKGFile(KGStreamRecord*, KGFileRec**, KGDictInt*, KGReferenceTableInt*) + 2560
    23 com.apple.FinalCutPro 0x001bbbf8 ReadKGFile(void*, KGStreamRecord*, KGReferenceTableInt*) + 240
    24 com.apple.FinalCutPro 0x001be4fc KGTypeReadValue + 188
    25 com.apple.FinalCutPro 0x0004063c KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 284
    26 com.apple.FinalCutPro 0x00040754 KGDictReadHash + 40
    27 com.apple.FinalCutPro 0x001a6b8c KGDictReadInternal + 172
    28 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    29 com.apple.FinalCutPro 0x001be584 KGTypeReadPtr + 96
    30 com.apple.FinalCutPro 0x0000ad18 KGDictReadArray + 320
    31 com.apple.FinalCutPro 0x001a6ba4 KGDictReadInternal + 196
    32 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    33 com.apple.FinalCutPro 0x001be4fc KGTypeReadValue + 188
    34 com.apple.FinalCutPro 0x0004063c KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 284
    35 com.apple.FinalCutPro 0x00040754 KGDictReadHash + 40
    36 com.apple.FinalCutPro 0x001a6b8c KGDictReadInternal + 172
    37 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    38 com.apple.FinalCutPro 0x001be584 KGTypeReadPtr + 96
    39 com.apple.FinalCutPro 0x0000ad18 KGDictReadArray + 320
    40 com.apple.FinalCutPro 0x001a6ba4 KGDictReadInternal + 196
    41 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    42 com.apple.FinalCutPro 0x001be4fc KGTypeReadValue + 188
    43 com.apple.FinalCutPro 0x0004063c KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 284
    44 com.apple.FinalCutPro 0x00040754 KGDictReadHash + 40
    45 com.apple.FinalCutPro 0x001a6b8c KGDictReadInternal + 172
    46 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    47 com.apple.FinalCutPro 0x001be4fc KGTypeReadValue + 188
    48 com.apple.FinalCutPro 0x0004063c KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 284
    49 com.apple.FinalCutPro 0x00040754 KGDictReadHash + 40
    50 com.apple.FinalCutPro 0x001a6b8c KGDictReadInternal + 172
    51 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    52 com.apple.FinalCutPro 0x001be4fc KGTypeReadValue + 188
    53 com.apple.FinalCutPro 0x0004063c KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 284
    54 com.apple.FinalCutPro 0x00040754 KGDictReadHash + 40
    55 com.apple.FinalCutPro 0x001a6b8c KGDictReadInternal + 172
    56 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    57 com.apple.FinalCutPro 0x001be584 KGTypeReadPtr + 96
    58 com.apple.FinalCutPro 0x0000ad18 KGDictReadArray + 320
    59 com.apple.FinalCutPro 0x001a6ba4 KGDictReadInternal + 196
    60 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    61 com.apple.FinalCutPro 0x001be4fc KGTypeReadValue + 188
    62 com.apple.FinalCutPro 0x0004063c KGDictReadHashCommon(KGDictInt**, KGStreamRecord*, KGReferenceTableInt*, KGDictInt* (*)(long)) + 284
    63 com.apple.FinalCutPro 0x00040754 KGDictReadHash + 40
    64 com.apple.FinalCutPro 0x001a6b8c KGDictReadInternal + 172
    65 com.apple.FinalCutPro 0x001b7704 ReadDict(void*, KGStreamRecord*, KGReferenceTableInt*) + 116
    66 com.apple.FinalCutPro 0x001be584 KGTypeReadPtr + 96
    67 com.apple.FinalCutPro 0x001a6ed4 pKGDictReadWithFlags(KGDictInt**, KGStreamRecord*, KGMessageableRec*, unsigned long) + 500
    68 …FinalCutPro.Plugins.Browser 0x015ee290 BrowserOpenFile(KGFileRec*, unsigned char, unsigned char) + 420
    69 …FinalCutPro.Plugins.Browser 0x015f1298 Browser(long, long, KGDictInt*, KGFileRec*) + 9996
    70 com.apple.FinalCutPro 0x00252624 CheckForOpenFile(KGFileSpec*, char*, unsigned char) + 308
    71 com.apple.FinalCutPro 0x00252744 pKGDisplayFile(KGFileSpec*, char*, unsigned char) + 16
    72 com.apple.FinalCutPro 0x003dd740 OpenDocuments(AEDesc const*, AEDesc*, long) + 244
    73 com.apple.AE 0x91500960 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 208
    74 com.apple.AE 0x915007fc dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 44
    75 com.apple.AE 0x91500654 aeProcessAppleEvent + 284
    76 com.apple.HIToolbox 0x932ae2e0 AEProcessAppleEvent + 60
    77 com.apple.FinalCutPro 0x001e60c8 Process1MacEvent(KGDictInt*) + 3356
    78 com.apple.FinalCutPro 0x001e625c KGMainEvent + 104
    79 com.apple.FinalCutPro 0x003de4b4 main + 832
    80 com.apple.FinalCutPro 0x0000430c _start + 392
    81 com.apple.FinalCutPro 0x00004180 start + 48
    Thread 1:
    2 com.apple.CoreFoundation 0x907de998 __CFRunLoopRun + 832
    3 com.apple.CoreFoundation 0x907de29c CFRunLoopRunSpecific + 268
    4 com.apple.CoreFoundation 0x907ed6fc CFRunLoopRun + 52
    5 com.apple.DVCPROHDMuxer 0x06f612bc AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 396
    Thread 2:
    Thread 3:
    3 …ickTimeComponents.component 0x9a050174 ReadSchedulerThreadEntryPoint + 5316
    Thread 4:
    cr: 0x24242222 xer: 0x0000000000000004 lr: 0x0000000004d4bcf4 ctr: 0x0000000090bb5aa8
    r0: 0x0000000004d4bcf4 r1: 0x00000000bfffc440 r2: 0x0000000000000006 r3: 0x0000000000000000
    r4: 0x00000000bfffc530 r5: 0x0000000000000018 r6: 0x0000000074653f2e r7: 0x0000000069707200
    r8: 0x00000000746c6573 r9: 0x0000000000000000 r10: 0x00000000686f70ff r11: 0x0000000004d546dc
    r12: 0x0000000090bb5aa8 r13: 0x00000000fffff800 r14: 0x00000000bfffc890 r15: 0x00000000bfffc88c
    r16: 0x0000000000000000 r17: 0x00000000bfffd1fc r18: 0x00000000bfffc89c r19: 0x000000000100e944
    r24: 0x0000000000000000 r25: 0x000000000100ea10 r26: 0x0000000000000000 r27: 0x0000000000000000
    r28: 0x000000000c3c5490 r29: 0x00000000bfffc824 r30: 0x0000000000000000 r31: 0x0000000090bdec24
    0x12b0000 – 0x12b4fff com.apple.FinalCutPro.Plugins.AudioGroupsExport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x12b8000 – 0x12bdfff com.apple.FinalCutPro.Plugins.Cache Manager 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x12c0000 – 0x12c3fff com.apple.FinalCutPro.Plugins.CTHelper 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0x12de000 – 0x12edfff com.apple.FinalCutPro.Plugins.AudioMixer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x12f2000 – 0x12f9fff com.apple.FinalCutPro.Plugins.Effect Builder 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0x15aa000 – 0x15d7fff com.apple.FinalCutPro.Plugins.AfterEffects 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x15e4000 – 0x166ffff com.apple.FinalCutPro.Plugins.Browser 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0x1688000 – 0x169afff com.apple.FinalCutPro.CinemaTools 2.2 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0x16a3000 – 0x16bcfff com.apple.FinalCutPro.Plugins.EditTape 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0x16c2000 – 0x1707fff com.apple.FinalCutPro.Plugins.EDL Export 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0x1718000 – 0x1725fff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0x1734000 – 0x1760fff com.apple.FinalCutPro.Plugins.FCS Engine 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0x176e000 – 0x177efff com.apple.FinalCutPro.Plugins.FilterCustomEd 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0x1782000 – 0x1795fff com.apple.FinalCutPro.Plugins.FilterViewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0x1799000 – 0x17b0fff com.apple.FinalCutPro.Plugins.Flash 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0x17bb000 – 0x17e5fff com.apple.FinalCutPro.Plugins.G4 Accelerator 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/G4 Accelerator.bundle/Contents/MacOS/G4 Accelerator
    0x17ec000 – 0x17f8fff com.apple.FinalCutPro.Plugins.GenViewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0x3c84000 – 0x3c88fff com.apple.FinalCutPro.Plugins.LayerFileReader 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0x3c8c000 – 0x3cd1fff com.apple.FinalCutPro.Plugins.Media Manager 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0x3cdd000 – 0x3ce3fff com.apple.FinalCutPro.Plugins.MolokiniSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0x3cea000 – 0x3cf9fff com.apple.FinalCutPro.Plugins.Movie Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x3e05000 – 0x3e1bfff MolokiniTranslation /Final Cut Pro HD 4.5.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0x3e36000 – 0x3e4dfff com.apple.FinalCutPro.Plugins.Motion Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0x3e52000 – 0x3e64fff com.apple.FinalCutPro.Plugins.Movie Analyzer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0x3e70000 – 0x3e73fff com.apple.FinalCutPro.Plugins.NuggetExport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0x3e76000 – 0x3eddfff com.apple.FinalCutPro.Plugins.OMF Audio Export 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0x3ef5000 – 0x3efcfff com.apple.FinalCutPro.Plugins.Perf Analyzer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0x3f03000 – 0x3f0cfff com.apple.FinalCutPro.Plugins.Pulldown Support 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0x3f11000 – 0x3f3dfff com.apple.FinalCutPro.Plugins.QTM Reader 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0x3f4a000 – 0x3f7ffff com.apple.FinalCutPro.Plugins.QTRtEffects 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QTRtEffects.bundle/Contents/MacOS/QTRtEffects
    0x3f93000 – 0x3f9bfff com.apple.FinalCutPro.Plugins.QuickView 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0x3f9e000 – 0x3fa9fff com.apple.FinalCutPro.Plugins.Relink Media 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0x3fae000 – 0x401ffff com.apple.FinalCutPro.Plugins.Timeline Editor 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0x4031000 – 0x4037fff com.apple.FinalCutPro.Plugins.Transcoder 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0x403c000 – 0x404efff com.apple.FinalCutPro.Plugins.Transition Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0x4053000 – 0x406afff com.apple.FinalCutPro.Plugins.Trimming 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0x406f000 – 0x4076fff com.apple.FinalCutPro.Plugins.VDUSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0x407a000 – 0x408bfff com.apple.FinalCutPro.Plugins.VideoLog 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0x4090000 – 0x40aafff com.apple.FinalCutPro.Plugins.VoiceOver 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0x40b2000 – 0x40c3fff com.apple.FinalCutPro.Plugins.Waveform Monitor 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Waveform Monitor.bundle/Contents/MacOS/Waveform Monitor
    0x40c8000 – 0x4164fff com.apple.FinalCutPro.Plugins.XML Support 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0x4c98000 – 0x4ca8fff com.apple.FCP Uncompressed 422.component 1.0.5 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x4d4a000 – 0x4d53fff com.apple.LiveType.component 1.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x4d5f000 – 0x4dc3fff com.DivXInc.DivXDecoder 6.6.0 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x4f76000 – 0x4feffff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
    0x5000000 – 0x5077fff com.apple.DVCPROHDCodec 1.0 (112) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x508d000 – 0x5106fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x5aef000 – 0x5af6fff com.unsanity.smartcrashreports Smart Crash Reports version 1.2.1 (1.2.1) /Users/hannahdee/Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
    0x5bfc000 – 0x5bfdfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
    0x5f17000 – 0x5f30fff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
    0x5f94000 – 0x5f97fff com.apple.ATIRadeon8500GA 1.4.18 (4.1.8) /System/Library/Extensions/ATIRadeon8500GA.plugin/Contents/MacOS/ATIRadeon8500GA
    0x600a000 – 0x600efff com.apple.iokit.IOQTComponents 1.4 /System/Library/Components/IOQTComponents.component/Contents/MacOS/IOQTComponents
    0x6012000 – 0x6031fff com.apple.fcp.DVOutputUnit 1.2 /Final Cut Pro HD 4.5.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0x6116000 – 0x6225fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x6254000 – 0x626ffff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x6505000 – 0x675cfff com.apple.ATIRadeon8500GLDriver 1.4.18 (4.1.8) /System/Library/Extensions/ATIRadeon8500GLDriver.bundle/Contents/MacOS/ATIRadeon8500GLDriver
    0x6f4a000 – 0x6fdcfff com.apple.DVCPROHDMuxer 1.0 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x7105000 – 0x718efff com.apple.DVCPROHDAudio 1.0 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x721b000 – 0x7278fff com.apple.DVCPROHDVideoOutput 1.0 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x728b000 – 0x72c4fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x72ca000 – 0x72d1fff com.apple.DesktopVideoOut 1.2.1 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x72d5000 – 0x72dffff com.apple.IOFWDVComponents 1.7.9 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x7600000 – 0x76c2fff com.apple.audio.units.Components 1.3.4 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0xa85c000 – 0xaa95fff net.telestream.wmv.import 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0xaacb000 – 0xac7ffff net.telestream.wmv.advanced 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0x907bb000 – 0x90895fff com.apple.CoreFoundation 6.4.10 (368.33) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x90f92000 – 0x90fd4fff com.apple.CFNetwork 4.0 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x91d4f000 – 0x91e3dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x91e5c000 – 0x91e5cfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91e5e000 – 0x91f43fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91f4b000 – 0x91f6afff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91fd6000 – 0x92044fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x9204f000 – 0x920e4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x920fe000 – 0x92686fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x926b9000 – 0x929e4fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x92a14000 – 0x92b02fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92b05000 – 0x92b8dfff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x92bce000 – 0x92df9fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92f26000 – 0x92f44fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92f4f000 – 0x92fa9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92fc7000 – 0x92fc7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92fc9000 – 0x92fddfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92ff5000 – 0x93005fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x93011000 – 0x93026fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x93038000 – 0x930bffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x930d3000 – 0x930defff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x930e8000 – 0x93115fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x9312f000 – 0x9313efff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x9314a000 – 0x931b0fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x931e1000 – 0x93230fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x9325e000 – 0x9327bfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x9328d000 – 0x9329afff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x932a3000 – 0x935b1fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x93701000 – 0x9370dfff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x93712000 – 0x93732fff com.apple.DirectoryService.Framework 3.3 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x937a6000 – 0x937c6fff libmx.A.dylib /usr/lib/libmx.A.dylib
    0x937cc000 – 0x937ccfff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x937ce000 – 0x93e01fff com.apple.AppKit 6.4.10 (824.45) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9418e000 – 0x94200fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x94239000 – 0x942fefff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x94351000 – 0x94351fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x94353000 – 0x94513fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9455d000 – 0x9459afff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x945a2000 – 0x945f2fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x945fb000 – 0x94615fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x947c3000 – 0x947d2fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x947da000 – 0x947e7fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9482d000 – 0x94846fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x9484d000 – 0x94b77fff com.apple.QuickTime 7.4.0 (92) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94c5d000 – 0x94ccefff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x94e43000 – 0x94f73fff com.apple.AddressBook.framework 4.0.6 (490) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x95006000 – 0x95015fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x9501d000 – 0x9504afff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x95051000 – 0x95061fff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
    0x95065000 – 0x95094fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
    0x950a4000 – 0x950c1fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
    0x97d24000 – 0x97d43fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x9845a000 – 0x9851bfff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x98546000 – 0x98547fff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
    0x98549000 – 0x98556fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x9a038000 – 0x9abfefff com.apple.QuickTimeComponents.component 7.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x9ae57000 – 0x9ae5bfff com.apple.QuickTimeH264.component 7.2 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x9ae5d000 – 0x9af6cfff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x9b0e3000 – 0x9b1b0fff com.apple.QuickTimeMPEG4.component 7.2 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9bb7e000 – 0x9bb7ffff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9bb8c000 – 0x9bbd0fff com.apple.viceroy.codec 31.0 (31) /System/Library/Components/VCH263Codec.component/VCH263Codec
    Modem: Jump, V.92, Version 1.0
    USB Device: USB 2.0 LaCie Big Disk, LaCie, Up to 480 Mb/sec, 500 mA
  • May Bolton
    May 22, 2008 at 1:03 pm
    OS Version: 10.4.11 (Build 8S165)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Final Cut Pro HD 4.5.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [70]
    Version: 4.5 (4.5)
    Build Version: 2
    Project Name: FCPApp
    Source Version: 4860000
    PID: 330
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Thread 0 Crashed:
    0 …ple.CoreServices.CarbonCore 0x90bb5ab8 FSpMakeFSRef + 16
    1 …ple.CoreServices.CarbonCore 0x90bdf030 CallComponentFunctionCommon + 1044
    3 …ple.CoreServices.CarbonCore 0x90bdf1cc CallComponentFunctionCommon + 1456
    5 …ple.CoreServices.CarbonCore 0x90bdebb8 CallComponent + 260
    16 com.apple.FinalCutPro 0x0024edc4 pKGOpenFile(KGFileRec*, unsigned long) + 212
    19 com.apple.FinalCutPro 0x00250ae4 GetInfoFromReader(KGFileRec*, KGDictInt*, char*) + 452
    20 com.apple.FinalCutPro 0x00251e8c pKGFileAddOrCheckImport(KGFileSpec*, char*, KGDictInt*, KGFileRec**, KGFileRec**) + 776
    21 com.apple.FinalCutPro 0x00251960 pKGFileAdd(KGFileSpec*, char*, KGDictInt*, KGFileRec**) + 48
    Thread 1:
    0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
    1 libSystem.B.dylib 0x9000b29c mach_msg + 60
    6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 2:
    4 com.apple.audio.CoreAudio 0x91459524 HALRunLoop::OwnThread(void*) + 264
    5 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
    Thread 3:
    0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
    1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
    2 …ple.CoreServices.CarbonCore 0x90bf93f4 TSWaitOnSemaphoreCommon + 176
    4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 4:
    3 …ple.CoreServices.CarbonCore 0x90c03e9c AIOFileThread(void*) + 520
    Thread 0 crashed with PPC Thread State 64:
    srr0: 0x0000000090bb5ab8 srr1: 0x000000000200f030 vrsave: 0x0000000000000000
    r20: 0x0000000000000000 r21: 0x0000000000000000 r22: 0x00000000616c6973 r23: 0x0000000000000000
    Binary Images Description:
    0x1000 – 0x434fff com.apple.FinalCutPro 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Final Cut Pro
    0x17fc000 – 0x17fdfff com.apple.FinalCutPro.Plugins.Text Window 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
