Activity Forums VEGAS Pro Very slow rendering in Vegas 6; misc quality Q’s
  • Very slow rendering in Vegas 6; misc quality Q’s
    Posted by Da_sud on August 1, 2006 at 10:23 pm
    Hi folks!
    Somewhat new to this process, I’ve been working on putting some montages together of Fraps recorded game footage, and have been having an issue with Vegas’ rendering speed.
    I have a half hour worth of footage. The estimated render time is 24 hours. Now, working with WMM with a short excursion with Premiere, I know that render times for this should not be so astronomical – however – it’s not lying, I left it rendering while I went to work, came home, and the thing was only 33% done.
    Some background on this, if I may so provide:
    The files I am bringing in I have pre-compressed to DivX format via VirtualDUB. The reason for this is simple – I don’t have the hard drive space to leave uncompressed AVIs on my hard drive for indefinite amounts of time (especially considering a minute of footage is easily a gig of space).
    My .veg file is pretty straightforward. Imported compressed DivX clips, imported MP3s, and a bunch of titles with only a couple special effects applied on a couple titles. About as basic a file as you can get. The render time comes as a surprise, as I put a similar file together in Premiere, and it didn’t take as long (but I’ve had nothing but problems with it, and wish to stay Vegas).
    Another question if I can so indulge: thus far, the current compression of the files is pretty much the quality I want it at. I had lots of problems with Premiere in that it would slaughter my movie come render time (I got some crazy screenshots of “alternate realities” it created with my movies). I finally came across Vegas and it’s doing a pretty good job working with these compressed files – though, it could be somewhat better. The output quality of a render has a little bit of extra dithering to it – it sort of looks like the result of something compressed being recompressed. That makes sense, I suppose, considering the fact that with crossfades and titles I’m creating another different movie out of the files, but I was wondering if anyone had any tips to minimize any graphical loss of quality due to compression occuring a second time on a compressed file? Again, hard drive space is finite, so working with uncompressed files would be undesirable.
    Any help is appreciated. Thanks guys!
    Terje A. bergesen replied 20 years, 1 month ago 2 Members · 1 Reply
  • Terje A. bergesen
    August 2, 2006 at 12:32 am
    I understand your problem with uncompressed AVI and diskspace, but the problem is caused by pre-compressing your stuff with DivX. When you pre-compress it, you make Vegas uncompress it and then re-compress it for the rendering process, this will slow things down tremendously.
    The solution should simple, but it will require a lot more diskspace than the compressed DivX files. Do not convert your Fraps stuff to highly compressed DivX, convert it to only slightly compressed DV-AVI. This will take a lot more space than your DivX, but it will make the rendering process significantly faster.
    Going through the intermediary DV-AVI rather than DivX will also solve your artifacts problem.
    Editing and re-encoding highly compressed video like DivX simply is a Bad IdeaTM.
    Terje A. Bergesen
