Activity › Forums › Apple Final Cut Pro › Very simple question: how do I change the name of the Event?
Posted by Olly Lawer on October 18, 2012 at 9:57 amCannot figure out for the life of me how to do it. Tried double clicking, control clicking…
Olly Lawer
Olly Lawer replied 13 years, 10 months ago 4 Members · 6 Replies -
Loren Risker
October 18, 2012 at 7:59 pmYou can click it like you normally would in the finder, but if there are background processes going on it won’t let you. It can be very finicky.
OutOfFocus.TV – Original series, music videos, and entertainment for your couch. -
Claude Lyneis
October 19, 2012 at 4:12 amWhy not select the event in FCPX, go to file and use Duplicate the Event. A box comes up and you can name it whatever you like. Now the question is, if you then delete the original, do all the files remain? I haven’t test that.
Bill Davis
October 20, 2012 at 1:40 amDon’t double click or single click. Click (pause) click. You rename stuff in your Event Browser just like you re-name an icon on your desktop.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Olly Lawer
October 20, 2012 at 7:58 amThank you. Sure I tried that, but will try didn’t pauses. Bit odd isn’t it!
Olly Lawer
Bill Davis
October 20, 2012 at 10:06 pm[Olly Lawer] “Thank you. Sure I tried that, but will try didn’t pauses. Bit odd isn’t it!”
Well, not when you realize that it’s just exactly the same convention that’s operated for folders in the finder since the Mac was introduced.
As Loren noted above, the selection process can be disabled if X is processing elsewhere. And that trips up a LOT of people. So it’s possible to try to select something but have it simply not work until the “under the hood” stuff that you’re having X do (knowingly or not) have been completed.
X seems simple, but under the hood it’s actually quite complex. And because of that, it kinda rewards patience and additive learning, not so much “dammit, I just I want to click where I think I should and have X react precisely as I think it should” ) expectations.
Olly Lawer
October 21, 2012 at 12:17 amYou have just summed up my personality perfectly 🙂
Olly Lawer
