Activity Forums Adobe Premiere Pro Very new to premiere… and very lost. Questions inside :)
  • Very new to premiere… and very lost. Questions inside :)
    Posted by Derek Thiessen on January 31, 2010 at 3:57 pm
    I just started playing around with Premiere 2 days ago so forgive me if I’m asking the wrong/dumb questions.
    I’ll fill in what I’ve done so far.
    I created my project in DV – NTSC/Standard 32kHz as I had no idea which to use. The footage I’m using is widescreen 1280×720 in WMV format.
    Here are my questions: (I’m sure I’ll have more)
    1) Can I pull my current timeline from the standard 32kHz and put it in a Widescreen 48kHz while still having the editable timeline? Is the Widescreen 48kHz even the one I should be using?
    2) Original footage is 1280×720 and it appears that the Widescreen preset is 720×480 which is a different ratio. Can the size be changed to fit the video?
    3) When exporting the video, it comes out choppy and pixelated vs the original video which is smooth and clean. Output settings are for Windows Media, NTSC sourch to High Quality. What have I messed up?
    Michael Lorushe replied 16 years, 7 months ago 2 Members · 1 Reply
  • Michael Lorushe
    February 2, 2010 at 12:16 am
    Hi Derek,
    Generally you want your project settings to match the settings of your source footage, so at the very least you shouldn’t be using the DV – NTSC/Standard 32kHz preset since your footage is in high definition.
    In terms of the export, you probably used the wrong codec or/and used a frame rate that is different from your source material.
    Mike
    Michael Folorunsho
    Clicktone Media / Mike Does Media
    Creative Dynamic Video Production
    http://www.clicktonemedia.com
    http://www.mikedoesmedia.com
