Activity › Forums › Zaxwerks › Very much a rookie question..what and where are set assignments ?
  • Jon Okerstrom
    February 3, 2007 at 1:44 am
    You’re talking about Invigorator, of course.
    Click the red ball below the scene preview window. That brings up the set-up window. How, select one of the objects – either using a tool or by choosing it in the object menu. Look for a small numerical pop-up next to the object selector. Those numbers represent sets. Once you’ve assigned each object to the appropriate set, close the set-up window.
    Then, look for the set selection popup below the scene preview window. Choose a given set and animate it. Do the same for the other sets.
    I know this is very short and very fast, but does this help?
    Jon
  • Josh J. johnson
    February 5, 2007 at 5:18 pm
    Thanks Jon!
