Activity › Forums › Adobe Illustrator › Very basic problem with brush tool and colour
  • Very basic problem with brush tool and colour
    Posted by Win Edson on September 4, 2013 at 9:12 pm
    Sorry if this seems utterly basic, but I’ve googled this for the last 2 days and still can’t find a solution.
    When I select a colour and stroke size, then attempt to use the paintbrush tool (or pencil tool)- it defaults back to no colour and a thin black stroke.
    This does not happen when I use the pen or rectangle tools.
    I’m using CS 5.5.
    Any help much appreciated!
    Win
    Aaron Mellman replied 10 years, 6 months ago 3 Members · 2 Replies
  • Jonathan Ziegler
    September 5, 2013 at 3:36 pm
    Hey there, first off, what type of brush do you have selected? Also, if you have settings for a tablet or stylus and you’re using a mouse (for example, if the brush size is dependent on pressure), it can cause issues. Double-check your brush presets – you may have set something and not realized it. Barring that, you can always reset prefs (I think its CMD-OPT-SHIFT on startup or CTRL-ALT-SHIFT) or trash the prefs.
    Let us know. 🙂
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Aaron Mellman
    April 3, 2016 at 9:39 pm
    I’m having the exact same problem. I’ve reset all of my preferences and have even reinstalled Ai. Any help would be greatly appreciated.
