Activity › Forums › Blackmagic Design › Vertical Lines in FCP ftg & “The Big No-No” (screen shot included)
  • Vertical Lines in FCP ftg & “The Big No-No” (screen shot included)
    Posted by Jason Connolly on July 15, 2005 at 4:36 pm
    Hello the COW! (this is also posted in AE and Auto Duck forums)
    OK, so I did the big no-no…I updated my OS and updated Final Cut Pro in the middle of a project. Ugh. I don’t know what happened, but here are the details:
    Yesterday(July 13), I was working with some green screen footage exported from FCP to AE, in 16-bit. I was able to get a great key very easily, and there was a noticeable difference between the 8-bit key, and 16-bit key. The 16-bit was MUCH cleaner.
    OK, fast forward to today(July 14)… I updated my Mac OS from 10.4.1 to 10.4.2, and updated to FCP 5.0.2. Why? Because I use Automatic Duck plug-ins to Import/Export ftg between FCP and AE, and the Automatic Duck people said that FCP 5.0.2 fixed the bugs that was disabling video preview when using BlackMagic cards. With me so far?
    OK, so now when I open up the same project I was working with yesterday, in 16-bit, the footage has weird vertical lines running thru it, but when I switch to 8-bit, the footage looks fine. Here’s a side-by-side comparison | VIEW IMAGE |
    I don’t know if the updates have anything to do with this, but that’s the only thing that’s different from yesterday. I can work in 8-bit, but the comp I’m working on looks much better in 16-bit. I can render out all of the green screen ftg(with keys) at 8-bit, then import the keyed clips back into the project, put them into my comp, and then render the full comp at 16-bit. But, WHY is this happening??
    Ugh. Any feedback is welcome!!
    Jason
    Jason Connolly replied 21 years, 2 months ago 6 Members · 9 Replies
  • 9 Replies
  • Jason Connolly
    July 15, 2005 at 4:55 pm
    UPDATE:
    I also tried re-capturing(both with FCP and Decklink 5.0) footage with the new updates(OS X 10.4.2 & FCP 5.0.2), but I still get the same lines when I work in 16bit space in AE.
    JAson
  • Paul Ingvarsson
    July 15, 2005 at 9:16 pm
    A wild guess but take a look in the Shake forum where there have been discussions about the 10bit codecs not working properly in QT7 –
    Good luck
    Paul
    Freelance DS/Symphony
    London
  • Michaelle Stikich
    July 15, 2005 at 9:57 pm
    What are your render settings in FCP? Have you tried changing them, or deleting your renders and then re-rendering?
    gir
  • Jason Connolly
    July 15, 2005 at 10:41 pm
    Gir-
    In FCP, I am capturing at 29.97fps, uncompressed BlackMagic, 10-bit, NTSC, 4:2:2, 720×486(D1). These lines you see occur when I try to work in 16bit space in After Effects. The clips look fine in FCP.
    Yes, after I performed the upgrades, I deleted all media, re-captured, but still get those funky lines in 16bit space in After Effects.
    Thanks for your response!
    Jason
  • Jason J rodriguez
    July 18, 2005 at 4:20 am
    Are you using the Apple or the BM 10-bit codec?
    Try removing the BM codecs and recapture with the Apple codecs. I’ve seen this sort of situation happen where the AE render engine get’s “confused” by which V210 codec to use.
    Hope this helps,
    Jason Rodriguez
    Virginia Beach, VA
  • George Kalishkin
    July 18, 2005 at 9:06 am
    i got this problem too.
  • Chris Tomberlin
    July 21, 2005 at 5:03 pm
    I’ve seen the same problem here too. Haven’t had time to track it down yet though…
    Chris Tomberlin
    Editor/Compositor/Owner
    OutPost Pictures
  • Chris Tomberlin
    July 21, 2005 at 10:57 pm
    OK, I’ve narrowed down the problem, but unfortunately don’t have a solution. The problem is during the importing of any “v210” codec into AE. Basically, by turning things on and off in the AE preferences text file, I’ve been able to determine that you can bring in footage at 16bit (as long as its not v210) and you won’t get the green lines in AE when set to 16bit. You can also render out to a “v210” codec and no green lines. Unfortunately, if you are capturing uncompressed 10-bit in FCP, you are capturing with a v210 codec.
    This must be a Quicktime bug. Anybody geekier (and I mean that in the best possible way) than me able to support this argument?
    Chris Tomberlin
    OutPost Pictures
  • Jason Connolly
    July 22, 2005 at 1:55 pm
    Chris-
    Thanks very much for sharing the fruits of your troubleshooting! I agree, it must be a QT bug. Hopefully a patch will be issued soon. I’m going to try re-capturing with non-v210 codecs and see if I like the results.
    Jason
