Activity Forums Avid Media Composer Vertical hold…
  • Vertical hold…
    Posted by Adam Kurnitz on August 6, 2014 at 2:11 pm
    Hey,
    I’m working with Media Composer 6.5 and I’m trying to achieve a vertical hold look. There doesnt seem to be an effect that achieves this look on its own. Is there some combination of effects I’d need to use?
    Matthew Skeris replied 12 years ago 4 Members · 3 Replies
  • Glenn Sakatch
    August 6, 2014 at 3:31 pm
    Boris fX has bad tv effect.
    you could certainly play with two picture in picture effects stacked on top of each other animating, but a realistic animation might be difficult.
    Glenn
  • Nick Griffin
    August 9, 2014 at 8:41 pm
    Lots of effects packages have a “bad TV” filter. Boris Continuum Complete is the first that comes to mind AND I believe you can buy parts of the whole package individually. But, before you do you can check it out with their 14 day trial.
    Also Artbeats used to have a series of bad TV loops, but I don’t recall that any of them would simulate a vertical hold roll. You’d take thier looped footage into a top layer, apply AFX effects and experiment with different transfer modes to get the right amount of effect and underlying original image.
  • Matthew Skeris
    August 23, 2014 at 4:44 am
