Activity › Forums › DaVinci Resolve › Versions – V1 gets reset when switching with command-shift p/n?
  • Versions – V1 gets reset when switching with command-shift p/n?
    Posted by Andrew Smith on December 17, 2011 at 11:39 pm
    Hello
    I am finding that when i try to use the command-shift P&N shortcuts listed in the menu to switch between versions it keeps erasing my V1 grade instead of switching between 1 & 2?!
    I have had it work other times when i have more than 2 versions so what am i missing?
    Resolve v8.1.1 mac 10.6.8
    Andrew Smith replied 14 years, 9 months ago 2 Members · 4 Replies
  • Andrew Smith
    December 19, 2011 at 5:47 pm
    After doing more testing I am noticing again that when I add a version 2 just by right clicking and then try to right click and go back to version 1 it resets V1 erasing all of my grades?! I then have to reapply the saved grade for V1 and THEN switching between V1 & V2 works by right clicking.
    anyone from BMD out there?! I am very discouraged by the lack of email response to the support email provided in this forum.
  • Dan Moran
    December 21, 2011 at 12:29 pm
    Hey Andrew,
    Please do email us at davincihelp@blackmagic-design.com for any issues your having and we’ll make sure to help you out.
    Dan
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Dan Moran
    December 21, 2011 at 12:37 pm
    I’ve also just tested your steps with my system and i’m not getting the same result.
    If you could send me a detailed step by step to davincihelp I’d be more than happy to look into and replicate it for you.
    D
    Dan Moran
  • Andrew Smith
    December 27, 2011 at 6:57 am
    So it seems this problem is with my understanding of remote vs. local versions, when i try doing this with remote is works – still wrapping my head around it.
