Activity Forums Zaxwerks version 4.3.2 on ae cs3, problem
  • version 4.3.2 on ae cs3, problem
    Posted by Rick Neely on November 13, 2007 at 9:43 pm
    Hi, just bought and installed proanimator 4.3.2 on my AE CS3 (running power pc dual 1.8 mac g5, tiger)
    It installs fine and I see it in effects. When I apply to a solid layer, I click on the proanmator plugin box in the effects palete to edit, I type in text and then the main proanimator windows appears and then flutters a moment every two seconds. I can do nothing- I can edit in proanimator, I can’t exit an go back to after effects, I have no choice but to do a force quit.
    Can I get some help fixing this ‘bug'”?
    Rick
    Rick Neely replied 18 years, 10 months ago 3 Members · 3 Replies
  • Matt Rhodes
    November 13, 2007 at 11:50 pm
    Hi Rick.
    Do you have any floating panels in AE? ProAnimator doesn’t work properly if you have any floating panels.
    A solution is to make sure all of your panels are docked before opening the PA Set-Up window.
    Let us know if you still have a problem.
    Matt Rhodes
    Zaxwerks, Inc.
  • Serge Hamad
    November 13, 2007 at 11:54 pm
    Matt, Could you please check your mail? I just sent you an e-mail.
    Sorry to interrupt this thread this way. I just wanted to get your attention.
    Salut & sorry again.
    Serge
  • Rick Neely
    November 14, 2007 at 1:25 pm
    Matt,
    that trick worked. Weird little quirk but at least I’m running. thanks!
    Rick
