Activity Forums Media 100 Version 13 File Export.
  • Version 13 File Export.
    Posted by Gregg Michaels on March 13, 2009 at 8:23 pm
    Having trouble exporting self-contained quicktime with stereo mix option. The program has 2 busses–>1 for all sot tracks and 1 for all music tracks. I can only get bus 1 out on “stereo mix” option. Am I mis-interpreting what this is supposed to create? Had to master to digi-beta and re-digitize to work around.
    GM
    Gregg Michaels replied 17 years, 6 months ago 3 Members · 6 Replies
  • Floh Peters
    March 14, 2009 at 10:07 am
    [Gregg Michaels] “Having trouble exporting self-contained quicktime with stereo mix option. The program has 2 busses–>1 for all sot tracks and 1 for all music tracks. I can only get bus 1 out on “stereo mix” option. Am I mis-interpreting what this is supposed to create? Had to master to digi-beta and re-digitize to work around.”
    The “Stereo Mix“ option recreates the way the “older” version worked, exporting Bus 1 as your stereo mix. If you want to export one of the other buses, you can use the “Export Buses as separate tracks” function, which will give you a quicktime with multiple stereo audio tracks, one for each bus. In QuickTime player you then can easily delete the unwanted buses/tracks for this clip.
  • Wickham Strub
    March 14, 2009 at 2:57 pm
    Hey Greg,
    I just re-read your post after seeing Floh’s response. Are you saying that you get ONLY bus number 1 when you choose “Stereo Mix”?
    If so, that’s different, and it’s news to me.
    ~Wick
  • Gregg Michaels
    March 14, 2009 at 4:21 pm
    Ok, got it. Is there not an easy way to export what’s going to the channel 1-2 outs? What I’m hearing over the monitor is perfect. If I create a multi-track bus export, will the mix be the same?
    GM
  • Gregg Michaels
    March 14, 2009 at 4:36 pm
    Yes. I have a program with 8 Tracks. Tracks 1-4 are mapped to bus-1 and tracks 5-8 are going to bus-2. When I use the stereo mix option from the file export menu I only get bus-1 on the quicktime.
    GM
  • Wickham Strub
    March 15, 2009 at 1:22 am
    OK, I’m with you. That doesn’t sound right to me. I’ll see what I can find out when I’m back in the office (I’m out Monday the 16th).
    In the mean time… you should try exporting busses as separate tracks. What’s the workflow? Where is this file going from here? Is it possible to run a short test to ensure that you’ll get what you need at the other end of the workflow?
    ~Wick
  • Gregg Michaels
    March 15, 2009 at 7:52 pm
    The program is 1080i@29.97 XDCam-HD footage acquired the good old fashioned way. The codec used is Apple ProRes HQ. I’m going to experiment with the bus to tracks option. If that doesn’t work with good results, I’ll be going the mix down route to digi-beta. Unfortunately, I’m on a deadline with this one, but I can handle it with the digi workaround.
    GM
