Activity Forums Apple Final Cut Pro Legacy Verifying RAID block size
  • Verifying RAID block size
    Posted by Navarro Parker on July 4, 2008 at 10:29 pm
    I’m setting up an internal RAID from three 500MB SATA drives. Disk Utility will let me set the block size before I create the set. I’m choosing 128K since I edit mostly HD video. But after the RAID is created, I check block size by clicking on Options again and it says “32K” and the block size pop-up menu is grayed out.
    How can I verify what block size my RAID is using?
    Navarro Parker replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
