Activity Forums Media 100 Ver 13 more troubles
  • Ver 13 more troubles
    Posted by Mark Foerster on May 4, 2011 at 12:06 am
    A bit of background. I have ver 13 on OS 10.5.8 on one of my Hard Drives.
    I “upgraded” to 1.5 in Snow leopard on another Hard Drive. (Same Mac)
    I went to ver 1.5 because I need the latest aja firmware upgrade because
    “on the fly downconversion” (while digitizing) did not work on Ver 13 because of a aja issue. OK so M100 gives me a free upgrade – cool. The only problem is my Adobe after effects needs to be upgraded for 64 bit blah blah. OK fine I’ll work in “ole 13 – no probs. Well yes and no – everything cutting well but I can’t do any “processing of clips” like fast or slow motion. Using QT 7.6.6 -HELP this is getting rediculous.
    Mark
    Floh Peters replied 15 years, 4 months ago 2 Members · 1 Reply
  • Floh Peters
    May 4, 2011 at 9:27 am
    [Mark Foerster] “The only problem is my Adobe after effects needs to be upgraded for 64 bit blah blah”
    Which version of AE do you use? At least CS4 works nicely on Snow Leopard.
    [Mark Foerster] “everything cutting well but I can’t do any “processing of clips” like fast or slow motion.”
    What does happen if you try to process something? A crash? Nothing? Bad results? Some more details (including the wording of the error message if you are seeing one) would be helpful
