Activity Forums Adobe After Effects Velocity curve wheres the triangle??
  • Velocity curve wheres the triangle??
    Posted by Tkdvipers on April 8, 2006 at 9:19 pm
    Hi
    I am new to all of this so this is bot going to be very interesting.
    However I am stuck very very stuck. I am following a tutorial dvd from after effects 6.5 but am using 7 (thought it would be better to go with the newer product).
    However I am stuck at the point where you change the velocity of an object. The tutorial tells me to adjust the velocity by using the little triangle to the left of the position keyframe. But in 7 its not there!!! Where have they put it? If someone could help I would be much obliged
    Thanks again.
    Jackson
    John Dickinson replied 20 years, 5 months ago 2 Members · 1 Reply
