Activity Forums VEGAS Pro Vegas White Frames Problem
  • Vegas White Frames Problem
    Posted by Seven12 on December 10, 2006 at 1:02 pm
    I just got Sony Vegas 7.0a and I rendered a video and found that it
    would come up with blank white frames placing specific clips on a
    video that I rendered. The video the clips or sections come from, isn’t
    missing or it isn’t that there is simply nothing in the spot, because
    when I play it on the preview window, it plays it correctly (but
    without the added effects), but then when I render it, groups of frames
    just go white and then it goes back to the clip, and then blank white frames again. Can somebody please help me with this problem? Thanks in advanced
    Ulflaursen replied 19 years, 8 months ago 3 Members · 3 Replies
  • Seven12
    December 12, 2006 at 9:51 pm
    Please HELP!
  • Edward Troxel
    December 12, 2006 at 10:21 pm
    Try updating to 7.0c and see if that helps. Otherwise, I’ve never seen what you are describing.
    Edward Troxel
    JETDV Scripts
  • Ulflaursen
    December 25, 2006 at 6:48 am
    What is your input and output media?
    Is it DV to DV or DV to Mpeg f.ex.?
    I have never myself seen this in Vegas before.
    /Ulf
