Activity › Forums › VEGAS Pro › vegas vid edit problem
  • vegas vid edit problem
    Posted by Jason Barczewski on January 30, 2009 at 6:24 pm
    new to vegas…and …..well….editing in general. I just shot some widescreen footage and saved it as avi to my computer .
    if I play it in media player the layout of the footage is correct, when I upload it to Vegas 7, the screen is more narrow and the shot is made narrow in which I look squashed a bit from both sides.
    How do I correct this?
    thanks
    Danny Hays replied 17 years, 8 months ago 3 Members · 2 Replies
  • Rob Strobbe
    January 30, 2009 at 8:10 pm
    Did you set your Project Properties (File > Properties) to widescreen (16:9)? The default is 4:3.
    If you plan to use widescreen most of the time, choose a template from the dropdown at the top, check the box labeled “Start all new projects with these settings,” and hit Apply.
    Rob
  • Danny Hays
    February 1, 2009 at 3:45 pm
    Also try right clicking in the preview window and check simulate device aspect ratio. Hope this helps, Danny Hays
