Activity Forums VEGAS Pro Vegas shuts down at 10%
  • Vegas shuts down at 10%
    Posted by Paul Gregory on October 26, 2010 at 4:36 am
    Having rendered out my project as MPEG2 wide-screen transport stream I then decided to render it out again as an MPEG4 file. The reason for this was because few clips had been HD mov files along with a great many jpeg images, which are of higher resolution that the standard 720×576 Pal files. I used the same basic template I had before a had looked just fine when done before. These were Sony AVC MP4 set to best quality,2 pass, 1440×1080,progressive, pixel ratio 1.33 & B/R 10,000,000.
    Each time I have tried to render this out Vegas shuts down after about doing 10% of file. The portion of the file that had been produced won’t play in either Windows Media player 12 or VLC player yet as I said previous files rendered out & played beautifully with the same settings. Any ideas?
    Thanks in advance
    Stephen Mann replied 15 years, 10 months ago 2 Members · 3 Replies
  • Stephen Mann
    October 26, 2010 at 4:07 pm
    How does it shut down? Error, hang, Blue Screen of Death?
    I would first suspect not enough memory or not enough hard-disk. Since you have not added any system information in your profile, we can only guess.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Paul Gregory
    October 27, 2010 at 12:02 am
    The Vegas window just disappears from the screen. I’m running Windows 7 64 bit with an i7 920 processor & 6 GB ram. The HDD still has about 300GB free.
    Thanks in advance
  • Stephen Mann
    October 27, 2010 at 4:09 am
    Have you checked the task manager to make sure it’s really gone? It really sounds like a PC problem. If it were me, I would reinstall Vegas and try again.
    Steve Mann
    http://www.mmdv.com
