Activity Forums VEGAS Pro Vegas Settings??
  • Vegas Settings??
    Posted by Chris Campbell on July 27, 2008 at 3:53 am
    hey guys so my problem is after i render out my 3d animations with 3ds max into sequential images lets say 300 in this case and i drag and drop/import them onto my time line they separate them selves every 2 frames for a length of 1 frame for the entire set of images so its 2 frames and then 1 frame gap then 2 frames and 1 frame gap and so on for the entire set.
    p.s. i have my still image length set to 0.033 to attain 29.970 fps all other settings are default
    ANY IDEA’S?, QUESTIONS?, SOLUTIONS?
    Adam Rose esq. replied 18 years, 1 month ago 2 Members · 3 Replies
  • Adam Rose esq.
    July 27, 2008 at 8:36 am
    when you import them, are you using the ‘import image sequence’ method?
    in case not, try
    FILE/IMPORT/MEDIA/ – the tickbox in bottom left corner
  • Chris Campbell
    July 27, 2008 at 3:56 pm
    hey thanks very much!! worked perfectly. i wasn’t checking sequence tick box!! thanks again worked like a dream 🙂
  • Adam Rose esq.
    July 27, 2008 at 8:48 pm
    HTH 🙂
