Vegas rendering Black Screen with Audio
Posted by Kieran Burcham on February 2, 2013 at 8:34 pmHi,
I’ve recently edited a video review of the beta for the game “Crysis 3”, however when I try and render it out, it renders only the audio, no video at all. I have tried rendering loops and stuff as well as different formats, but its no good. I have resampling disabled.
Render settings:
https://gyazo.com/54f07d7b5e549120d264e83c8b21f19fJohn Rofrano replied 13 years, 8 months ago 2 Members · 5 Replies -
John Rofrano
February 2, 2013 at 9:57 pmI created a template that matched the one in your picture and it rendered fine on my Vegas Pro 12.0 workstation so it’s not your render template.
What codec does the source video use?
Do you have any codec-paks installed? (if so uninstall them and re-install Vegas Pro)
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Kieran Burcham
February 2, 2013 at 10:11 pmThe source is from a Roxio GameCapture HD PRO, converted to .mp4 using videowave and I have nothing installed, only Vegas…
John Rofrano
February 2, 2013 at 10:55 pm[Kieran Burcham] “The source is from a Roxio GameCapture HD PRO, converted to .mp4 using videowave and I have nothing installed, only Vegas..”
OK, Here are two thing to try:
(1) Create a new project with just a Sony Text Title in it and try and render with that template. This will tell you if there is a render problem with the template. (I assume this will work)
(2) Place one of the MP4 files in a new project and try and render it with that template (assuming #1 worked). This will tell you if the problem is the source video. (I assume this will not work)
Let us know what you find out.
~jr
Kieran Burcham
February 3, 2013 at 12:08 amAlrighty so just before you posted this I tried re-rendering again, and it worked but the audio is tinny and out of sync by about a second, itll do for this video but how do I fix it?
John Rofrano
February 3, 2013 at 2:05 am[Kieran Burcham] “it worked but the audio is tinny and out of sync by about a second, itll do for this video but how do I fix it?”
Did you apply any FX to the audio? Is it not tinny in the project but is in the render? What did you change on the audio tab of that render template?
~jr
