Vegas Rendered Quality
Hello,
I’m having issues with quality of my Sony Vegas 9.0c renders. I’m shooting my footage with a Canon GL2, in standard mode (non-frame) and i’m seeing noticeable horizontal lines during movement.
Now i’m aware this has to do with interlacing as well as field order, however, i’ve attempted to render with virtually every combination of settings available and i cannot seem to rid myself of the issue – though I can reduce it somewhat.
So far the best solution has been project settings with: no field order (progressive scan) and deinterlace method set to interpolate fields or lower field first and deinterlace method set to blend fields.
What doesn’t make sense to me is that if I match my project settings to the footage I captured directly from the Sony GL2 in Vegas, the field order is set to lower field first. From the research i’ve done, it appears that the GL2’s standard footage should be a progressive scan by default.
Additionally, when filming in Frame Movie Mode – i do not experience the horizontal line issue. I suppose the easy solution is “film everying in frame mode from now on,” but i’d prefer to understand why this is occurring.
Thanks to everyone in advance for any assistance.
