Activity Forums VEGAS Pro Vegas pulling in wrong file
  • Vegas pulling in wrong file
    Posted by Kevin Labonty on December 11, 2006 at 2:45 pm
    I am using Vegas 6.0d. I had a project and pulled in a new file with raw video, put it in the trimmer window, and added a bunch of scenes (events). Then I saved the project, burned a DVD and everything was fine. Went back into the project this morning and every scene I added is from a different video file! The durations and placement in the timeline of the events are correct, but the video within the event is not. It is pointing to a different video file which is in the project but not the one I used to originally do all the add’s from the trimmer window. Any idea’s? Did I lose everything?
    Kevin Labonty replied 19 years, 8 months ago 2 Members · 2 Replies
  • Edward Troxel
    December 11, 2006 at 4:09 pm
    Right click the “wrong” file, choose “Replace”, and replace it with the right file.
    Edward Troxel
    JETDV Scripts
  • Kevin Labonty
    December 12, 2006 at 2:45 am
    Ed: I need a little more help please.
    When I right click the event in the time line and choose select in project media, it takes me to the correct file in the project media window.
    When I right click the event and select properties, the file pointer is to the incorrect file. I can not change the file name here.
    I don’t want to choose replace in the project media bin because it is the correct file. Also, the project uses both the “correct” and “incorrect” files in different scenes, so I will need both.
    Any idea’s?
