Activity Forums VEGAS Pro Vegas PRO preview completely messed up
  • Vegas PRO preview completely messed up
    Posted by Ellis Holban on February 22, 2018 at 10:36 pm
    I’ve been using Vegas for a while now, but there’s this one problem that recently got me stuck and annoyed, when I dragged the video into the tracks, it was fine. However, when I cut the video anywhere, the preview is almost completely covered in black and opposite colours. I rendered the looped region, and half of it was very messed up but then the rest of it was fine. As well if I dragged the line across the track, almost the entire video seems to gimped in the preview. But when I play the entire video from the beginning, some parts are gimped but then the rest of the video is fine, including the looped region where I cut it. But when I try to render it, it goes black in the same places. It’s a bit hard to explain. I’ve tried multiple ways to get rid of it as well as looking online for a solution, but to no avail.
    Here’s a screenshot for my situation.
    Someone please help me.
    Ellis Holban replied 8 years, 7 months ago 2 Members · 6 Replies
  • Graham Bernard
    February 23, 2018 at 2:45 am
    Supply us with:
    A)MediaInfo information.
    B) PC specifications.
    Also try these fixes:
    1) Turn off GPU.
    2) If you have 32bit Floating point revert to 8 bit.
    3) Match Project Settings to the Media.
    4) Do a Factory Reset of Vegas.
    * Grazie
  • Ellis Holban
    February 23, 2018 at 5:10 am
    1. If you’re talking about the open-source program, I don’t have it. If you referring to my media information, it’s 2256×1504, and the bitrate is 3649 kbps. Also 60 fps.
    2. I use Sony Vegas on two computers, the first one is an HP Pavilion with a Intel(R) Core (TM) 17-4790 CPU @ 3.60 GHz processor with 8 gb of ram. The second is a Microsoft Surface with an Intel(R) Core(TM) 15-7200U CPU @ 2.50GHz 2.71 GHz processor with 4 gb or ram. Both computers experience the same problems when the same video is in Vegas.
    I’ve tried all your steps, but nothing worked. Including the reset. Now I’m starting to get a tad bit worried.
  • Graham Bernard
    February 23, 2018 at 5:34 am
    [Ellis Holban] “I’ve tried all your steps, but nothing worked. Including the reset. Now I’m starting to get a tad bit worried.”
    Hmm… Is that 4k Media you are successfully Previewing, prior to making an edit? I also note that your Preview Output is Progressive but your Media is Interlace. Why? Did you match your Project Settings to the Media? I could understand that the Prog Preview would be fine, but on making an Edit this may get issues in then Previewing for a possible under-specced system, if you are running 4k.
    MediaInfo would greatly assist us. Including myself, it’s used by many people here. It’s a great little diagnostic assist.
    My thoughts? – There is some badly fitting math going on and your platforms are trying to play catch-up after an edit.
    * Grazie
  • Ellis Holban
    February 23, 2018 at 6:27 am
    Alright, so I got MediaInfo and I’m viewing the media I’m using for the video. How can I tell if it’s 4K? And how do I tell if the media is interlaced? Can I change the media from interlaced to progressive? I’m not a very tech savvy person. One thing to note is that the media is footage I recorded on ZSNES, a SNES emulator. I have tried editing ZSNES footage prior to today, and I didn’t have that problem, until now. (I think) The problem showed up when I changed the Encoder on OBS from x264 to QuickSync H.264. I’m not changing it to anything else because the frame rate drops significantly when I change it back. So is there any way that this problem can be resolved?
  • Graham Bernard
    February 23, 2018 at 7:06 am
    [Ellis Holban] ” (I think) The problem showed up when I changed the Encoder on OBS from x264 to QuickSync H.264.”
    Yup, that’ll be the issue that is creating mayhem. Try a fresh sample with your previous setup. If that works then that’s a controlled experiment to confirm that everything else falls back on your change.
    Get yourself to the Official MAGIX Vegas Pro site. There will be others to assist and many more having had this issue.
    HTH?
    G
    * Grazie
  • Ellis Holban
    February 24, 2018 at 9:12 am
    OK, I came up with a solution. I will continue to record my videos in 4K, but I will convert the videos from 4K to 1080p using Handbrake. I’ve tried that and it works for me.
