Activity Forums VEGAS Pro Vegas Pro has stopped working
  • Vegas Pro has stopped working
    Posted by Art Willig on April 26, 2016 at 4:29 am
    Suddenly getting these errors in Vegas Pro 10.
    Have no idea why this would suddenly happen.
    However, after closing, it says that the SYSTEM has recovered from a serious error so I’m thinking perhaps Windows XP Pro is messed.
    What do you think?
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0c (Build 469)
    Problem: Unmanaged Exception (0xc000001d)
    Fault Module: C:\WINDOWS\system32\SHELL32.dll
    Fault Address: 0x7CD0DF3C
    Fault Offset: 0x0034DF3C
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Process Version: Version 10.0c (Build 469)
    Process Description: Vegas Pro
    Process Image Date: 2011-01-03 (Mon Jan 03) 17:02:04
    Problem Description
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\WINDOWS\system32\ntdll.dll
    Fault Address: 0x7C9113A0
    Fault Offset: 0x000113A0
    Problem Description
    Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\FileIO Plug-Ins\compoundplug\mc_dec_avc.dll
    Fault Address: 0x1DC1AE7D
    Fault Offset: 0x001EAE7D
    Art Willig replied 10 years, 4 months ago 3 Members · 4 Replies
  • Mike Kujbida
    April 26, 2016 at 10:00 am
    You’re running 10.c and 10.e is the latest version for Pro 10 so I recommend upgrading to it first and see if your problems go away.
    https://www.sonycreativesoftware.com/download/updates/vegasfamily
  • Art Willig
    April 26, 2016 at 7:59 pm
    Updated to 10e…still the same problem.
    Getting these OS errors now…
    LOCALS~1\Temp\WER4690.dir00\Mini042616-02.dmp
    LOCALS~1\Temp\WER4690.dir00\sysdata.xml
    Offhand, it looks like it can’t open the hundreds of clips on the timeline. It stops and throws the vegas has stop working error.
  • Aaron Star
    April 26, 2016 at 8:13 pm
    You know Win10 with Vegas 13 B473 is probably more stable and feature rich.
    With some huge number of files, you may be hitting the memory ceiling for 32-bit Vegas. Upgrading to Win10-64 and Vegas 13 may solve this if this is the issue. Not sure what type a project would require a huge number of source files to hit that ceiling. If you are trying to do timelapse, use image sequence import vs dropping on the timeline.
    Here are a few things to try with such an old system:
    Clean it out top to bottom, and reseat cards and memory
    Run CCleaner – Reboot
    Run Malware Bytes and check for bugs.
    Check HDD for surface errors or failures.
    Then test RAM for failing blocks with Memtest86+ outside of windows, and run a complete set of tests. Any errors found at all mean you need new ram in that slot.
    Upgrade the machine to something modern
  • Art Willig
    April 27, 2016 at 9:20 pm
    I first ran memtest86+ which threw millions of errors before I shut it off. Then I opened the box only to find one of the memory stick has popped out. Everything works again.
    I’ve hundreds of short clips on the timeline that I copy to another timeline. I was wondering if I should put these in media folders or does it really matter?
