Vegas Pro Generic Control – doesn’t work in 15 but seems does in 14
Posted by Sonic Vision on March 22, 2018 at 6:29 amHello,
Any advice for Vegas Pro Generic Control ?
I’m trying to setup my MIDI Control Surface and have some basic transport functions working in VP14 but nothing at all in VP15 (all same settings).
I have done extensive setup in Digital Audio Workstations and was really hoping to get this going VP15.
Sonic Vision replied 8 years, 5 months ago 2 Members · 11 Replies -
Graham Bernard
March 22, 2018 at 2:36 pmMCU. I’ve got a PreSonus FaderPort8 and I’ve got some control. What you got and what has happened so far?
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Sonic Vision
March 23, 2018 at 2:09 amThanks for your reply.
I have tried both Generic and MCU and neither do a single thing. They both do work in VP14.
Quite frustrating.
Graham Bernard
March 23, 2018 at 5:02 amDo make sure VP14 isn’t being active as a Control Surface when you check out VP15. Be assured it does work in VP15. And yes, it’s very frustrating.
* Grazie
Sonic Vision
March 23, 2018 at 8:04 amI’m assuming if I have completely closed VP14 then it isn’t conflicting. Even before I tried all this in VP14 it woudn’t work in VP15. That is what lead me to trying VP14 and finding out it is working there.
Graham Bernard
March 23, 2018 at 8:31 am[Sonic Vision] “I’m assuming if I have completely closed VP14 then it isn’t conflicting.”
Yeah, so would I . . . Just try and disable anything MIDI Control Surface or anything related in VP14 and then start over with VP15.
* Grazie
Graham Bernard
March 24, 2018 at 7:55 am[Sonic Vision] “Still nada.”
Hmm…
This is what I have.
Timeline with that RED Alert Line on the Track Header:
Have you got these setup correctly?
MIDI Tab:External Control and Automation:
“External Control” – Activated under Options:
And finally this is what I get when played and the Latched and Written Volume Envelope using the Faders on the Presonus FaderPort8:
* Grazie
Sonic Vision
March 26, 2018 at 1:22 amGood Sir Graham!
I most appreciated this clear pictorial! You solved the issue!
It was the 2nd to last screen shot “Options Menu > External Control > Checked”. Mine wasn’t checked, doh!
Thank you, thank you!
I owe you a beverage ☺
Grazie!!!
Sonic Vision
March 26, 2018 at 7:34 pmGraham,
I do have another question, if you don’t mind:
I believe you are using MCU – are you able to edit the functions? I know how to this in the Generic mode but in MCU I can’t figure it out, if it’s even possible. I have lots of buttons, and some knobs, on my surface and it would be nice to be able to assign them so I know what is where. Right now all I know is fast forward, rewind, play, stop, record and jog/shuttle wheel (all transport commands).
In the Generic editor I can set these but the jog/shuttle won’t work like it does in Mackie MCU mode.
So I can have a decent transport and shuttle wheel setup in MCU, or assignable functions in Generic but non working shuttle ☺
Finally is there way to mark a post as “Resolved”. Most forums I can edit a post to state that but haven’t found any such thing here.
Thanks.
Graham Bernard
March 26, 2018 at 8:05 pm[Sonic Vision] “I believe you are using MCU – are you able to edit the functions?”
Yes, MCU. When you say edit functions do you mean assign KEYS on your external controller to functions within Vegas? Then yes, yes I can using MCU. BUT, depending on your Control Surface – mine’s that Presonus FaderPort8 – it is limited and not a smooth ride!
[Sonic Vision] “I know how to this in the Generic mode but in MCU I can’t figure it out, if it’s even possible.”
Sure, that could be the case. I don’t use Generic and stayed with MCU. Does your Control Surface allow for MCU Emulation?
* Grazie
