Activity › Forums › VEGAS Pro › Vegas Pro 9.0d released
  • Mike Kujbida
    April 12, 2010 at 1:12 pm
    Notable fixes/changes in Version 9.0d
    * Added closed captioning support (reading and writing of XDCAM HD and HD422 closed captions, as well as .SCC file import/export).
    * Added support for the PreSonus FaderPort control surface.
    * Added Device Explorer support for CompactFlash-based memory recording units such as the HVR-MRC1 and hard-disk-based recording units such as the HVR-DR60.
    * Added support for AVCHD Lite video.
    * Added support for timecode in XDCAM EX AVI/DV files.
    * Tools > Multicamera > Lay Out Tracks Using Media Timecode and Lay Out Tracks Using Media Date/Time Stamp now use unique tracks for media without tape names.
    * Added support for importing layered PSD files across tracks.
    * Added White Balance video plug-in.
    * Added scripts: Remove Letterboxing, Render Audio Tracks, Resize Generated Media, and Stereo To Mono.
    * Copy Snapshot to Clipboard and Save Snapshot to File now deinterlace interlaced images and operate at Best (Full) resolution if the Video Preview is set to (Auto) size and Good quality if set to Draft or Preview.
    * Copy Snapshot to Clipboard now performs pixel-aspect correction like the Save Snapshot to File command.
    * Added Copy Snapshot to Clipboard and Save Snapshot to File to the Trimmer.
    * Added timeline DVD burning (Tools > Burn Disc > DVD).
    * Updated to latest RED SDK, including support for 4.5K images and FLUT color science.
    * élastique Efficient is now the default time stretch mode.
    * MPEG-2 smart render across formats now supports MPEG-2 video streams intended for Blu-ray Disc (only available when operating points are identical: e.g. resolution, framerate, video data rate, color resolution).
    * The Mastering Effects Bundle 2 plug-ins (available with Sound Forge Pro 10) can now be used in Vegas Pro if they are installed on your system.
    * Implemented various compatibility improvements to XDCAM MXF files.
    * Improved support for reading AVC/AAC (.mp4) video.
    * Improved image sharpness on Windows Secondary Monitor display when Apply deinterlace filter is not used.
    * Improved Trimmer Fit-to-Fill behavior when the source is a still image.
    * Implemented various additions and improvements to Interactive Tutorials.
    * Fixed a crash that could occur during startup when using the 64-bit version of the application with certain RAID controllers.
    * Fixed a crash that could occur when adding certain audio effects to the Master Bus FX chain.
    * Fixed a hang that could occur while changing FX parameters with an external DV monitor enabled.
    * Fixed a hang that could occur when using 32-bit VST audio effects in the 64-bit version of the application.
    * Fixed a hang that could occur after capturing HDV clips.
    * Fixed field order in reader for certain H.264 files.
    * Fixed Import Stereo as Dual Mono when dragging media from the Device Explorer window.
    * Fixed a smart render issue with XDCAM HD.
    * Fixed a smart render issue with MXF PAL DV rendered to AVI PAL DV.
    * Fixed timecode reading for 50p and 60p XDCAM MXF media.
    * Fixed an issue with waveform drawing accuracy when very quiet events are normalized.
    * Fixed an issue that could prevent audio from appearing for certain AVI files.
    * Fixed a crash that could occur when rendering many markers to Sony MXF format.
    * Fixed a bug that could cause clicks when using certain Track EQ automation settings.
    * Fixed an issue where deleting one Track Motion preset could cause others to be removed.
    * Fixed a slight artifact that could occur when using the Broadcast Colors video effect.
    * Improved support for VST audio plug-ins written in Delphi.
    * Fixed a problem that could cause summary data to be lost when using custom Windows Media Video rendering templates.
    * Fixed a problem with enabling the audio stream when using custom Windows Media Video rendering templates.
    * Fixed the ability to capture from HDCA-702 MPEG TS Adaptor.
    * Fixed the ability to render to multiple mono files using PCA format.
    * Fixed the ability to seek in files rendered using the MainConcept AAC/AVC format.
    * Fixed a problem that could cause corrupt video when rendering to QuickTime format using the 3 Mbps Video template.
    * Fixed the operation of the Proportional check box in the Checkerboard generator plug-in.
    * Fixed an issue with media generators not using a changed pixel aspect ratio.
    * Fixed an issue saving and restoring templates in the Command Properties dialog.
    * Fixed an issue that prevented JPEG from being used to save image sequences.
    * Fixed an issue with Trimmer Fit-to-Fill not creating the correct media start time.
    * Fixed an issue with scrubbing in reverse past the media start time in the Trimmer.
    * Fixed issue with Event Pan/Crop Match Output Aspect when Adjust source media to better match project or render settings applied to the source media.
    * Fixed an issue that prevented markers from appearing in the correct position for rendered FLAC files.
    * Corrected a problem that could cause black frames in MOV files after installing the QuickTime 7.6.6 update.
  • Stewart Bourke
    April 12, 2010 at 8:17 pm
    Would anybody know if there are likely to be any VMS to pro upgrade ‘specials’ around this release? I am thinking about upgrading from VMS to pro, and if historically, upgrades like this prompted specials, I light hold off for a while to see if anything was coming down the tracks…
    Stewart Bourke
  • Theo Van laar
    April 12, 2010 at 8:25 pm
    Ok, I installed the 32bits Vegas pro 9d upgrade and tried to open the project I was working on.
    This is the error message I get. Any ideas what is happening?
    Theo
  • Theo Van laar
    April 12, 2010 at 8:40 pm
    Update: I have deinstalled 9d and reinstalled 9c. Now the project works fine again. Anybody else having the same problem?
    Theo
  • Mike Kujbida
    April 12, 2010 at 9:26 pm
    [Stewart Bourke] “Would anybody know if there are likely to be any VMS to pro upgrade ‘specials’ around this release?”
    This is a point upgrade, not a brand new version and that’s the only time that I’ve seen ‘special’ pricing offers.
    New version time for Vegas Pro is typically in September (at least for the last few releases).
  • Theo Van laar
    April 13, 2010 at 6:53 am
    From the e-mail from Sony:
    20% off Vegas Pro and Vegas Pro Upgrades*
    With Vegas Pro 9.0d out today, there’s more reason than ever to make the leap to version 9. Need a little more encouragement? Take 20% off any Vegas Pro new purchase or upgrade through April 30, 2010.
    Buy Today!
    *Offers valid April 12 – April 30, 2010. Offer available only when purchasing directly from Sony Creative Software via links in this email.
    Theo
  • Stewart Bourke
    April 14, 2010 at 12:11 am
    Interesting – I am a registered owner of VMS, but have not received such emails – maybe it only relates to pro users… pity, I’ll drop a note to Sony to see…
    thanks for letting me know
    Stewart Bourke
  • Alexander Kim
    April 18, 2010 at 7:40 pm
    https://www.sonycreativesoftware.com/news/newsletter
    The link is on the left. Thank you Theo for posting that information. Saved me $120 🙂
