Activity Forums VEGAS Pro Vegas Pro 9.0 b released
  • Vegas Pro 9.0 b released
    Posted by Mike Kujbida on August 28, 2009 at 12:05 am
    Get it here.
    Notable fixes/changes in Version 9.0b
    * Resolved an issue that could cause the contents of media generators (most often text generators) to change when the Undo command was used.
    * Fixed a bug that could cause Vegas to crash during startup on some computers running Windows XP.
    * Fixed a bug that could cause still images to appear out of focus when rotated via Event Pan/Crop.
    * Fixed a bug that could cause audio dropouts in XDCAM SD (DVCAM) MXF files.
    * Fixed a bug that could cause an error when conforming trimmed XDCAM clips on the PDW-U1 deck.
    * Fixed a bug that prevented some QuickTime files from reading audio properly.
    * Fixed a bug that prevented metadata from being imported with 720-50p XDCAM clips.
    Eric Kirk replied 16 years, 11 months ago 4 Members · 3 Replies
  • Kevin Mccarthy
    August 29, 2009 at 2:53 am
    Any idea if this update fixed the render issues?
  • Craig Simpson
    August 29, 2009 at 10:32 am
    Hasn’t for me, its just minor fixes.
    Tried rendering again still the same issues.
  • Eric Kirk
    October 4, 2009 at 7:36 pm
    Hello,
    I’ve seen a few messages on this. Somehow I missed the 9.0b update but just got it. From the posts, it seems it has done little to correct rendering issues.
    I seem to constantly get shut down while rendering and what it surprising is that they are relatively low file size renders, like trying to render even as low as 512kbps. I’ve tried as high as 19020×1080 and down to 720….still crashes and says I have low memory. But surprisingly, I can render a huge avi at the highest settings. I’m running XP with 4GB (3.25GB) like many others.
    Any ideas on how to fix this?
    Eric
    Kirk Productionsns
    Eric D. Kirk
    http://www.kirkproductions.com
