Vegas Pro 8.1 freezing
Posted by Jesse Davenport on September 17, 2009 at 3:29 amI’ve been editing my new film on Vegas Pro 8.1 which was said to work better with a 64-bit system. I’ve gotten to almost to the half hour point and the thing keeps freezing. If anyone can help me ASAP I would greatly appreciate it.
Jesse Davenport replied 16 years, 11 months ago 4 Members · 8 Replies -
D. Eric franks
September 17, 2009 at 2:11 pmI always found 8.0 32-bit to be more stable on my Vista 64 system. In any case, it’s definitely possible to install both 32- and 64-bit versions and if the 64-bit gives you a hard time, you can open the project up in the 32-bit. (Frankly, I’m doing that right now with v9-64, which is a lot more stable, but I’ve still run into issues that were most easily solved by popping back temporarily into the 32-bitter.)
_____________
“My advice to young film-makers is this: Don’t follow trends, Start them!”
— Frank Capra
https://videopia.org -
Brandon Brand
September 17, 2009 at 6:29 pmHi Jesse
What is your system spec? Have you maybe tried driver updates, the important ones would be bios,chipset,VGA and sound.
That would be a good start for diagnosing your feezing problem for using SV 64bit version. I would like to help you on this one. 🙂PS – SV is awesome!
Jesse Davenport
September 17, 2009 at 9:33 pmIt was working fine before and it still loads the project AND I even managed to cut it up into more than one project, but on each project as soon as it finishes loading, I can’t click on anything. This is my system:
Manufacturer: Gateway
Processor: Intel(R)Core(TM)2 Quad CPU Q9300 @ 2.50 GHz 2.50 GHz
RAM: 4GB -
Brandon Brand
September 18, 2009 at 10:23 amLike you said it was working fine before, Maybe you should look at some application you have installed or you could have made a change somewhere on your system that could affect the running of Vegas.
Jesse Davenport
September 18, 2009 at 9:38 pmI was editing the film and when I was adding some clips and music it just froze up and it won’t let me edit any of the material. I really have no idea what made it happen so I have no idea how to fix it.
Brandon Brand
September 21, 2009 at 7:27 amDo you have another machine to copy the project and thy rendering it on that machine?
Dave Haynie
October 26, 2009 at 5:40 amYeah, it does that… Vegas 8.1 is not too stable.
The point wasn’t so much working better on a 64-bit system, as releasing a native 64-bit version for us to play around with. One big advantage of a 64-bit system is access to more than 4GB of memory… but only if you have a native 64-bit application. A small advantage is that code can sometimes run a bit faster… though it can also run slower in other situations.
Anyway, the 32-bit version of Vegas 8 will work just dandy on a 64-bit system as well.
You may want both, anyway, but the first thing I’d do in your shoes is install the 32-bit version of Vegas 8, which is far more stable, and see how it does on your project.
One thing to consider.. when you install a 64-bit version of Vegas, you need to install other 64-bit stuff for it to play nicely with, such as plug-ins and CODECs. It’s quite possible some of the cool stuff you have for 32-bit Vegas won’t yet exist for 64-bit Vegas.
Vegas 9 comes in 32-bit and 64-bit versions, too. Overall I have found it a bit more stable than Vegas 8, and quite a bit moreso than Vegas 8.1.
-Dave
Jesse Davenport
October 26, 2009 at 7:07 pmWhich version of Pro 9 would work best with a 64-bit system?
