Activity › Forums › VEGAS Pro › Vegas Pro (8.0c) unable to render a 2hour HDV timeline? Any possible solution?
  • Vegas Pro (8.0c) unable to render a 2hour HDV timeline? Any possible solution?
    Posted by Fotis Vassis on November 11, 2008 at 9:02 pm
    Till now I have been experimenting with short clips of my HDV camcorder (Sony HC9) with success.
    Now I have captured two tapes with 2 hours of video (1440×1080 50i) put them in the timeline, a few transitions and a few cuts and there it is ready.
    Nevertheless when I try to render to Blu Ray 1440×1080 50i 25mbs stream Vegas reaches up to somewhere 40% and suddenly the application closes by it self. I have tried disabling the antivirus, disabling LAN and several other silly things but no joy. My PC has a P4 3.4 cpu with 2 GB ram with freshly installed WinXP Pro SP3 and Vegas predicted a 7hour rendering for the 2hour timeline. No problem with time but it never finishes.
    For the time being I divided the timeline into three 40minute regions and manually doing each region rendering which works ok and I will “join” them later in DVD Architect.
    Do you have any idea what could go wrong and can you suggest an automated way to render the 3 regions in such a clever way so I don’t have to wait for one render to finish in order to start another?
    Thanks in advance
    Interchefs Culinary Club
    The Interactive Gourmet Experience
    Jeremy Rasnic replied 17 years, 10 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    November 12, 2008 at 5:28 pm
    I would urge you to watch your page file usage in the task manager (ctrl+alt+del) and see if it pegs out at around 40%. If so, you are using up all of your memory. If you have large pictures in your project (a lot of megapixels) shrink them down to a size that is equal to your project (if you are doing a lot of zooms and panning you will want to make the picture just a little bigger than the maximum you zoom in (so it doesn’t pixelate).
    Thanks in advance
    Ultimate S (www.vasst.com) is a collection of scripts that allows for you to do back to back renders as well as a bunch of other things that would normally take you a lot of time to do, but faster . Excalibur may do this as well but I am unsure.
    j razz
