Activity Forums VEGAS Pro Vegas Pro 23 won’t open
  • Vegas Pro 23 won’t open
    Posted by mike fuller on May 7, 2026 at 1:30 am
    So I had already 4 instances of Vegas running and I opened a 5th, typically I stick with 4 as a max. Well Vegas wouldn’t load, so I closed all Vegas instances and rebooted, it still won’t open, I have tried
    running as administrator
    holding ctrl shift while clicking on the file
    nothing works. Each time I delete any Vegas process in the task manager before trying again
    Mads Nybo jørgensen
    replied 3 months ago
    3 Members · 5 Replies
  • Rob Xpyakyalo
    May 7, 2026 at 2:27 am
    Why would you need so many open instances? Sorry I never do that with software…
  • mike fuller
    May 7, 2026 at 3:27 am
    I usually jump back and forth between projects. Update. Vegas finally opened, it just took forever
    May 7, 2026 at 10:26 am
    Hey Mike,
    Great that you got it to open again.
    Would be interesting to know your machine specs?
    Although, you are sorted:
    Good idea to check how much space you have on your drive?
    Where is your Virtual memory sitting, and how much space does it take?
    Don’t know if you use CCleaner, it starts from free, but can help you clean your drive for orphan files – just make sure to make back-up of registry before cleaning it.
    Hope this helps?
  • mike fuller
    May 7, 2026 at 4:37 pm
    Well I spoke to soon, yes I somehow have one instance of vegas open, however I cannot open a new project file if I click on it in explorer, nothing happens. same if I try to open the program with it’s executable icon.
    Now I am afraid to turn off my computer.
    I can though load a project into vegas and edit it. now it won’t let me drag new media into the timeline.
    Not sure about the virtual memory, my ssd is nearly full though.
    May 7, 2026 at 6:22 pm
    Hey Mike,
    That’s annoying.
    Sounds like you need to free up space:
    What does your System > Storage > Temporary files show?
    WARNING: DO NOT “REMOVE YOUR DOWNLOADS FILES” – unless you have checked them, or backed them up to a seperate folder.
    Have you deleted render files (temporary pre-renders) for all of your projects?
    If going manual, A.I. suggests: “often found in
    C:\Users\<username>\AppData\Local\VEGAS Pro\<version>\
    or the folder defined in your project properties.”
    If you have it, could you add an external drive for you to free up space on the main drive?
