Activity › Forums › VEGAS Pro › VEGAS pro 16 over 16 hours to render only a 1080P movie?
  • VEGAS pro 16 over 16 hours to render only a 1080P movie?
    Posted by Jackie Luffy on June 19, 2019 at 12:44 am
    Hey guys! I seem to be having a problem with extremely long render times, I have a i9 processor, 32 gigs of ram, and a 1060 gtx nvidia graphics card which is plenty to chew through 4K so 1080P should be peanuts yet this 1 hour and 50 minute 1080P only film I have rendering out is going painfully slow, its only got to about 3% in an hour and says that the ETA is over 18 hours!? There is no way this can be right does anyone have any recommendations as to whats going on? Its as if Vegas isn’t taking advantage of my hardware or something
    Also I figured I’d mention that I have all my project files on a lightning fast m.2 ssd drive and its saying it will take this long, thanks for the help in advance 🙂
    Jackie Luffy replied 7 years, 3 months ago 2 Members · 3 Replies
  • Jackie Luffy
    June 19, 2019 at 12:53 am
    WOW for anyone who has the same problem you need to switch the encoder from Mainconcept to NV encoder and the DIFFERENCE IS NIGHT AND DAY it went from like 20 hours to literally under an hour now this will be done rendering, crazy
  • Michael Hoogasian
    June 19, 2019 at 3:07 pm
    [Jackie Luffy] “WOW for anyone who has the same problem you need to switch the encoder from Mainconcept to NV encoder and the DIFFERENCE IS NIGHT AND DAY it went from like 20 hours to literally under an hour now this will be done rendering, crazy”
    Keep in mind that rendering using the GPU may not produce the same quality as rendering with the CPU, due to, for example, half-precision floating point vs. full precision.
  • Jackie Luffy
    June 21, 2019 at 4:56 pm
    I have thought of that there must be some sort of catch but after viewing and watching large sections of the two 1H and 50 minute films It looks like its absolutely perfect 1080P quality all through, what in particular would I have to watch out for? It seems the frame rate, the quality and sound are all flawless
