Activity Forums VEGAS Pro Vegas Pro 14 Suite vs Vegas Pro 15 Suite – rendering speed test benchmark
  • Vegas Pro 14 Suite vs Vegas Pro 15 Suite – rendering speed test benchmark
    Posted by Marcin Zmyslowski on August 29, 2017 at 11:03 am
    Hello!
    Video presents benchmark rendering speed test in Magix Vegas Pro 14 Suite vs Magix Vegas Pro 15 Suite.
    Rendering speed test was taken on the following PC:
    CPU: Intel i9-7900X (20 threads)
    GPU: Nvidia GTX 980 TI
    Memory Flash SSD: Samsung 960 EVO M.2
    System: Windows 10 Home
    RAM: 64 GB
    Video presents CPU Load, GPU Load, rendering time on both Vegas Pro 14 and 15.
    Input video raw file: 4K AVC 29.97fps 60 Mbps – duration: 2 min. 30 sec
    Output video file: 4K XAVC S 29.97fps 60 Mbps – czas: 2 min. i 30 sec.
    Here is a link to the video:
    https://youtu.be/k32L2OY9cc4
    Kindest regards
    Marcin from Poland
    Ryan Gray replied 8 years, 11 months ago 3 Members · 2 Replies
  • Nigel O’neill
    August 29, 2017 at 10:35 pm
    In short: 11 minutes 19 seconds using v14 and 9m 35s under v15 under the same conditions
    My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Ryan Gray
    September 26, 2017 at 4:24 am
    What is the absolute BEST graphic card for rendering 4K material down to HD 1080p files or 480p (DVD) files? I have an AMD Ryzen processor and an AMD RX 580 GPU….but sometimes during rendering in Vegas Pro 13 it does fine and then inexplicably stops and says 0 frames rendered, black screen. Nada. Don’t know what is causing this. Is there a better card that I should use? Or should I upgrade to VP14 or 15, do they handle 4K any better?
