Activity Forums VEGAS Pro Vegas Pro 14.0 Omitting Frames During Credits
  • Vegas Pro 14.0 Omitting Frames During Credits
    Posted by Isaac Beals on January 10, 2022 at 7:15 am
    Hey everybody!
    I have a video file that contains a pre-rendered credits scroll (black with white text) and when I open it in VLC and advance it frame-by-frame, it plays perfectly (each frame advances the credits).
    But when I import that same file into Vegas Pro, making sure to match the framerate, it plays three frames fine, then “duplicates” frame three into frame four (the credits don’t move) and then frame five catches up (the credits jump twice as far). Even after rendering, this “skipping” still occurs.
    The strange thing is, this doesn’t happen anywhere else in the video. I tried advancing frame-by-frame in other places and it plays out smoothly.
    I tried doubling the frame rate to see what it looks like, but it seems like that fourth frame just doesn’t exist at all. Also, I tried uploading the same video but in a different format (MPEG-1, 23.976 FPS) and it worked just fine, so the trouble seems to be with my file.
    I’m stumped, to say the least.
    Here are my video specs:
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Duration : 4 s 171 ms
    Bit rate mode : Variable
    Bit rate : 34.4 Gb/s
    Maximum bit rate : 27.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 (24000/1001)
    FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Scan order : 2:3 Pulldown
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 690.931
    Time code of first frame : 00:00:00;00
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 16.7 GiB (98%)
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    Computer Specs:
    Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz
    16.0 GB
    64-bit operating system, x64-based processor
    Windows 10 Home
    (And I attached a picture of my Vegas Pro properties)
    Isaac Beals replied 4 years, 7 months ago 1 Member · 1 Reply
  • Isaac Beals
    January 10, 2022 at 9:05 am
    Okay, I tried importing the same file but at a lower bitrate and it works fine, so it seems to have something to do with the bitrate. But I still have no clue how to fix it.
