Vegas Pro 13.0 Weird problem when adding text/Video Effects
Posted by Ricardo Caro on February 8, 2016 at 4:13 pmNeed help!! 🙂
Generated Media Box is not fully showed, as you can see in this clip:
https://gyazo.com/bf6e744d457b2620d7842b439d18bbf2same thing happens with video FXs
Graham Bernard replied 10 years, 6 months ago 6 Members · 9 Replies -
Graham Bernard
February 8, 2016 at 4:59 pmYeah, this rings a bell. What Build of VP13 is that?
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Steve Rhoden
February 9, 2016 at 2:14 amHave you already tried re-installing and resetting Vegas?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Mike Kujbida
February 9, 2016 at 3:24 amIf you adjusted your monitor font size larger than 100%, set back to normal size.
John Rofrano
February 9, 2016 at 4:39 am[Mike Kujbida] “If you adjusted your monitor font size larger than 100%, set back to normal size.”
+1
Yea, setting your monitor DPI to anything other than 100% will mess up applications. This is a really poorly implemented feature in Windows. Always keep your display size at 100%.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
Colin Moxey
February 10, 2016 at 12:58 pmThanks Ricardo for bringing up this subject. I have the same thing happening, but only when I use MEDIA GENERATORS/Credit Roll.
Thank you Mike and John for your suggestions regarding the monitor DPI setting at 100%.
I’m set at this and still have the problem.
I blame myself for setting up 2 monitors. I cannot fault Sony Vegas as this happened when I was using version Pro 12 and now with Pro 13 -453
Ricardo, did the suggested fix work ok for you?
thanks guys -
Graham Bernard
February 11, 2016 at 8:57 pmUpdate your Video Driver?
I’m trying here!
* Grazie
