Activity Forums VEGAS Pro vegas pro 13 (64 bit) xvid/mp4 file opens but looks like and renders like garbage (used to work in vegas 12)
  • vegas pro 13 (64 bit) xvid/mp4 file opens but looks like and renders like garbage (used to work in vegas 12)
    Posted by Richard Prieto on August 17, 2014 at 6:49 pm
    Relevant screenshots below:
    I used to be able to work with these files in Vegas 12, but now when I try to edit or render them, they look like this mess. I uninstalled K-lite and reinstalled vegas 13, and then the standalone xvid plugin from xvid.org, to no avail. Is there anything else I can try? Thank you in advance!
    Richard Prieto replied 11 years, 10 months ago 2 Members · 3 Replies
  • Graham Bernard
    August 18, 2014 at 6:51 am
    You could try Editing using Proxies, which is an option in VP13.
    Grazie
  • Richard Prieto
    August 19, 2014 at 12:41 am
    If I do that, then it tells me “No compatible video codec was found”…. Is it trying to use the wrong codec? Is there a different one I can install besides the one at xvid.org? I’m not sure why this is an issue since Vegas Pro 12 64-bit handled these just fine.
  • Richard Prieto
    August 21, 2014 at 9:22 pm
    Just an update on this…. Basically it doesnt work right away, but sometimes it will work if I jigger around with it a bit. For example if I click “load in trimmer” then “load in project media list” then “create video proxy” (which results in a no codec found message) then load in trimmer again, it will suddenly start being able to work with the clips. It makes no sense. But unless someone can chime in with a permanent solution, I have no choice but to keep doing this every time I want to load up Vegas and work with these clips.
