Activity Forums VEGAS Pro Vegas pro 12 Transcode or Render Audio from 44.1 to 48KHZ
  • Vegas pro 12 Transcode or Render Audio from 44.1 to 48KHZ
    Posted by Wayne Grauel on April 2, 2023 at 5:40 pm
    Whats the best way to convert 44.1 audio from a digital recorder to 48Khz to sync audio and video in Vegas pro12? Do i import the “audio as 48khz” or Render the 44.1 audio from the time line as 48khz.
    It’s been a while and I’ll have to use audio from a digital recorder that only records in 44.1 to place in the time line with video.
    Many thanks
    Wayne
    Aivis Zons replied 3 years, 5 months ago 2 Members · 1 Reply
  • Aivis Zons
    April 3, 2023 at 1:26 am
    I would say that if possible importing as 48khz is preferable as then you preserve the original quality of the audio file, but realistically if you do an uncompressed render to 48khz in vegas there shouldn’t be a noticeable difference anyway.
    Personally I haven’t really ran into any problems with mismatching samples rates in the past by just making sure that everything matches – source, project, render.
